Install Intake/Exhaust Manifold - JeepForum.com
post #1 of 2 Old 03-25-2002, 07:03 PM Thread Starter
Ryan McMenamin
Is it better to install the Intake/Exhaust manifolds as one piece, or to install the exhaust first and the intake on top of it?
I've tried it both ways... and well... I'm asking the question because I can't seem to get everything to line up.
One or the other lines up with the head correctly, but not both. I can get both of them lined up perfectly, but then the connection between the two won't screw down...
Ideas?
Ryan
1988 YJ 4.2 - I6 - Stock but with aspirations for greatness
Ryan McMenamin is offline
post #2 of 2 Old 03-30-2002, 11:18 PM
93 Blue Demon YJ
well, I have the 4.0, but I imagine its the same. I assume you have everything off, and you are beginning to put it back on. you put the exhaust on first, and put the 2 outer bolts on loosely to hold it in place. Next, you put on the intake manifold. you can line it up accordingly to the hole, and the bolt should go between the intake/exhaust manifolds. put the bolds on in a clockwise and outward path...starting in the middle working out. couple words of advice...1. always put on a new manifld gasket. 2...make sure you toque all the bolts to the proper torque, and recheck them about a week or so later, mine were 13 ft.-lbs I believe. hope this helps, if you need more info let me know.
Richard
'93 YJ 4.0 3" RC lift 15x10 wheels and 32" tires.
93 Blue Demon YJ is offline
Changing intake manifold and exhaust manifold Gaskets Cards89YJ YJ Wrangler Technical Forum 17 01-13-2012 05:32 PM
Intake and exhaust manifold ? on 2.5 semperfi96 YJ Wrangler Technical Forum 3 09-26-2009 12:36 PM
Intake/Exhaust manifold??? BChamberlin TJ Wrangler Technical Forum 3 08-08-2007 11:22 PM
intake manifold and exhaust funJ YJ Wrangler Technical Forum 1 06-09-2006 09:53 PM
intake/exhaust manifold bruins YJ Wrangler Technical Forum 0 03-06-2004 10:12 AM
