Inside of frame cleaning? - Page 2 - JeepForum.com
post #16 of 32 Old 01-30-2011, 09:59 AM
lckdrgn
Live in California, Bay area, no rust.
lckdrgn is offline
post #17 of 32 Old 01-30-2011, 11:39 AM
CreepyCrawler95
you could clean the inside out and fill the frame with GreatStuff
CreepyCrawler95 is offline
post #18 of 32 Old 01-30-2011, 01:15 PM
Mike1091
Like some guys said I heard foam spray and that kind of stuff just holds water in and makes it rust more. I plan on using this stuff this summer when i clean my frame up.
http://www.eastwood.com/internal-fra...ay-nozzle.html
Mike1091 is offline
post #19 of 32 Old 01-30-2011, 02:35 PM
ssyj94
The best way to coat the inside of your frame is take the frame to a galvinzer and have it acid dipped then galvenized. A friend of mine did this to his f350 frame a few years ago and it worked great. Other than that clean it out a with a powerwasher or garden hose when you wash your jeep.
My build:
ssyj94 is offline
post #20 of 32 Old 01-30-2011, 07:48 PM
CreepyCrawler95
great stuff is what is used to fill holes and put up moisture barriers
post #21 of 32 Old 01-30-2011, 09:10 PM
plym49
The Brits have a product called Waxoyl that puts down a nice waxy film. It is used on inner panels like frames and inner rockers.
You can make your own by mixing lanolin with paint thinner.
If you want to go all out, check out Aircraft Spruce. They sell special aerosol products that are engineered to wick uphill inside all areas of an enclosed cavity and deposit a rust-inhibiting coating that flexes and deals with rust or grease already in there. They are used on older aircraft where corrosion inside a steel frame is a very expensive and dangerous condition. The aerosols are a little pricey but well worth it in terms of ease of application and piece of mind.
plym49 is offline
post #22 of 32 Old 07-11-2013, 04:06 PM
HighRoller02TJ
im going to try to bring this thread back to life, maybe get some new ideas. today I put a garden hose in the larger holes on the side and blasted it with water, then I took a shop vac and duct taped a clear plastic flexible hose onto the shop vac hose and snaked it through the frame and sucked up all the water, dirt and chunks of rust that didn't drain out, next im going to spray the inside with the eastwood internal frame coating.
HighRoller02TJ is offline
post #23 of 32 Old 07-11-2013, 07:28 PM
calvynandhobbs
calvynandhobbs's Avatar
That's exactly what i plan to do to my YJ when I start working on it. I already have the Eastwood internal frame coating cans in the barn. Just have to finish with my big sidewalk and retaining wall project before I get to work on the Jeep.
94 YJ - work in progress
calvynandhobbs is offline
post #24 of 32 Old 07-13-2013, 10:16 AM
UZI4U
I hit all of the frame holes whenever I hit the car wash. When I got my Jeep, the rails were packed. I might have some rocks in there, but no more mud comes out.
MCLMM
UZI4U is offline
post #25 of 32 Old 07-13-2013, 11:54 AM
kjg26
kjg26's Avatar
How many cans of the eastwoods internal frame coating are needed?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #26 of 32 Old 07-13-2013, 02:05 PM
HighRoller02TJ
I was told 2
post #27 of 32 Old 03-29-2015, 01:25 AM
TrumpetRider
What if there are rust flakes in the frame larger than the hole near the rear LCA mount?
I'm still confused on the best way to blow all this crap out of my frame rails before I coat them :\
TrumpetRider is offline
post #28 of 32 Old 03-29-2015, 07:15 AM
Mike Romain
A coat hanger or screwdriver can maybe break them up, but if your frame is that rotted inside and shows any cracks or rust outside, it is time to look for a replacement. Someone cut holes in the tail end of my replacement frame so they could get all the crap out, then they blasted and painted it up pretty and sold it to a sucker, me... I even coated the insides good with cold galvanising compound before installing, but it was too late. Just street and dirt road driving caused it to fall apart, it was just plain rotted from the insides out.
Mike
Mike Romain is offline
post #29 of 32 Old 03-30-2015, 08:56 AM
HaskiE
HaskiE's Avatar
I was told 2
I bought 6 and used 4 to get two coats... used another one on the windshield frame.
Make sure you tape all the holes except the one you snake it into...It gets EVERYWHERE!
I did this cut (to patch rust) after I coated the inside.
#theneverendingaxe
HaskiE is offline
post #30 of 32 Old 03-30-2015, 09:02 AM
HaskiE
HaskiE's Avatar
I had the luxury of having the frame completely bare - I just beat it with a mallet, cut some holes for the stuff to fall out, and shook it around and let all the stuff fall out, then stuffed a hose in there and cleaned it as best I could. I guess if it was still a jeep you could blow/vacuum the rust out with compressed air/ pressure washer/ vacuum/etc.
#theneverendingaxe
HaskiE is offline
Cleaning in the Frame... jerseyjeep22 TJ Wrangler Technical Forum 5 01-06-2010 06:53 AM
Cleaning/coating INSIDE the frame? TJamz TJ Wrangler Technical Forum 6 04-22-2009 10:42 PM
Cleaning the inside of the soft top UnsanePyro TJ Wrangler Technical Forum 2 08-10-2006 10:54 PM
cleaning the INSIDE of tinted soft top windows base shakers TJ Wrangler Technical Forum 22 10-22-2005 05:15 AM
cleaning the inside of a CD player TJdave TJ Wrangler Technical Forum 1 10-04-2004 05:48 PM
