Inside of frame cleaning? - JeepForum.com
post #1 of 32 Old 05-26-2008, 11:39 PM Thread Starter
ImportEater
Well Im currently rebuilding my rig. The outside of the frame needs to be cleaned and painted. If I look inside the frame at the end of the frame rails, I can see minor surface rust near the opening.
How does one clean this rust off and out? Pressure washer? Media blaster?
Im having fun doing this build, but if I do all this work just to have the frame rot from the inside out, Il lbe mad.
I dont want to swap the frame, I dont think its needed. I just need to get the frame clean inside and out.
As always, thank for the help.
ImportEater is offline
post #2 of 32 Old 05-27-2008, 05:14 AM
krd
i've heard of guys putting alittle used motor oil in. never tried it though.
258 str.6 w/1" mml, nuttered, 32/36 weber carb, hei, TF-999 w/hurst floor shift, np231 w/aa slip yoke eliminator, jks quick discos, 3-1/2" fabtech, 1" bl, MORE 5/8" boomerangs front and rear, dana 44's front and rear 4.56 locked, herculined tub and family style roll bar, jks u-bolt plates, xenon flat fenders, rrc pre-runner, custom built rear bumper, Gen-right rock sliders and hood louvers, 35" mtz micky t's, bullet proof high steer, bestop soft top w/tinted windows.
1988 yj
2007 gmc 2500 crew cab
2009 volvo xc70 turbo
1988 porsche 911
krd is offline
post #3 of 32 Old 05-27-2008, 01:47 PM Thread Starter
ImportEater
I heard that too. I have plenty of that lying around.
I just want to be able to get all the surface rust out first, then oil it you know.
I hate asking this, but, can you cut part of the top frame rail off, then clean the inside and then weld it closed? I know cutting the frame is a last resort for alot of repairs, but I really want a rust free rig.
post #4 of 32 Old 05-27-2008, 02:25 PM
Lumpymayo
Only thing I can think of is to just drill small holes in the frame and use an undercoating spray gun and just spray por 15 in the inside of it. I guess you can sand blast the inside of it prior using this method.
Lumpymayo is offline
post #5 of 32 Old 05-27-2008, 02:29 PM
jimaug87
My last YJ rusted from the inside out too, so I'd be interested in hearing some solutions too.
2005, I6, 6 Speed, RC 2.5", RC front adj. track bar, 31" Goodyear DuraTracs
"Nobody is comepletly useless. We can always serve as a bad example."
jimaug87 is offline
post #6 of 32 Old 01-29-2011, 07:47 PM
Palmetto
Palmetto's Avatar
1981 CJ7
Anybody ever follow up on this? This is my dilemma as well.
Palmetto is offline
post #7 of 32 Old 01-29-2011, 08:09 PM
4.7stroker
http://cgi.ebay.com/Rust-protection-...item43a4d70a07
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #8 of 32 Old 01-29-2011, 08:32 PM
CreepyCrawler95
if you can get ahold of some phosphoric acid (make sure you use safety first with this stuff ;] ) get a decent sprayer and spray a fair amount on the inside. let it sit for about 30 mins...spray the inside with water to wash out... find some sort of heat blaster to dry it out... repeat acid...repeat wash and dry...coat it with POR15.
i know this is possible ive been wanting to do it for quite some time without cutting into the frame. if you try and accomplish this let me know because i do know that acid will obliterate any rust or oxidation
CreepyCrawler95 is offline
post #9 of 32 Old 01-29-2011, 08:41 PM
burnout189
i know this is not 100% on topic, but i (along with many others) drilled about a half inch hole in the bottom of the rear crossmember (at rear bumper) to make it easier to hose the mud and gunk out from inside. it gives it a place to go.
maybe that will give someone an idea.
BARNHART'S AUTO REPAIR
burnout189 is offline
post #10 of 32 Old 01-29-2011, 10:04 PM
buzzbait122
Tried the drain oil trick on my TJ, kinda worked on the lowest points in the frame but the rest immediately dried out. Gonna try urethane foam on the YJ. My Silverado has this stuff on the inside of the rocker pannels and it seems to work pretty good.
buzzbait122 is offline
post #11 of 32 Old 01-29-2011, 10:21 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If the frame is really rusty, it needs the bad sections to be cut out and replaced. If you have surface rust, don't worry about it. If you really feel the need to do something about surface rust, apply POR-15.
Urethane foam is another word for sponge. It will hold water and accelerate rusting.
Every spring and fall, stuff a garden hose in the frame rail holes and flush out any dirt, mud, salt, sand, or other goop. It is not short term exposure to water that rusts out Jeep frames, it is the damp mud and goop that holds water long term that causes rust.
CJ7-Tim is offline
post #12 of 32 Old 01-29-2011, 10:31 PM
sbsg2005
http://www.eastwood.com/rust-solutions/removal.html
Many of the products on this site can be used on rust all you would need is a wand type sprayer and use it to reach through the existing factory holes in the frame. I believe they may even have a sprayer and a coating specifically for the inside of frames.
sbsg2005 is offline
post #13 of 32 Old 01-29-2011, 10:58 PM
buzzbait122
The stuff used in my Silverado is absolutly waterproof and bonded really good to the metal. It's the stuff used in autobody repair, not the stuff sold in home impovment stores. Anything that excludes water and oxygen will prevent rust. My only concern with using it is what happens when welding nearby.
post #14 of 32 Old 01-29-2011, 11:04 PM
cushtech
I use Eastwood's Anti-Rust.
In a warm month flush out your frame and get all the gunk out of it.
You have to get all the stuff out that's trapping moisture.
Let it dry.
Spray the Anti-Rust in there with an undercoating gun with a wand.
(Wear a mask, gloves and some old clothes!)
http://www.eastwood.com/ew-heavy-dut...rust-32oz.html
http://www.eastwood.com/review/produ.../category/236/
Eastwood anti-rust is a wax that will coat and protect the interior of your frame in the same way as the oil treatment. I repeat this about 2 times a year. So far it's worked well. If you have major rust inside your frame you might need to use another product.
cushtech is offline
post #15 of 32 Old 01-30-2011, 09:12 AM
Old4X
1990 CJ7
There is a product called "CorrosionX" that is made for just this situation.
It is sprayed from a can or wand, neutralizes rust, and protects for about 2 years.
It was developed for the aircraft industry, definitely not a "snake-oil" product. I have used it, and it works.
(note: I don't sell it or work for the company, just a satisfied user).
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
Cleaning in the Frame... jerseyjeep22 TJ Wrangler Technical Forum 5 01-06-2010 06:53 AM
Cleaning/coating INSIDE the frame? TJamz TJ Wrangler Technical Forum 6 04-22-2009 10:42 PM
Cleaning the inside of the soft top UnsanePyro TJ Wrangler Technical Forum 2 08-10-2006 10:54 PM
cleaning the INSIDE of tinted soft top windows base shakers TJ Wrangler Technical Forum 22 10-22-2005 05:15 AM
cleaning the inside of a CD player TJdave TJ Wrangler Technical Forum 1 10-04-2004 05:48 PM
