Inside Door handle - JeepForum.com
post #1 of 4 Old 10-10-2001, 04:21 AM Thread Starter
helter
Inside Door handle
OK - last fall my drivers side inside door handle broke on my 92 YJ - there's a little plastic piece that hooks a rod to the inside handle door lock and door handle. The little plastic piece snaps and you're out of luck. Well - it just happened again - I have to reach out the window to open the drivers side door.
Does any after market company make a door handle for the full YJ doors that's made of METAL rather than plastic? or at least has metal hardware on the inside so it won't snap when it gets cold out?
Any help would be appreciated.
92 YJ - 30x9.5 BFG
helter is offline
post #2 of 4 Old 10-10-2001, 09:22 AM
powjunkie
Not sure about the handle, but has anyone had trouble with the door locks on the full doors in cold weather? I've had to take mine apart a couple of times to bend the rod so they'll lock and unlock. I've been thinking about mounting a motor and tapping into the alarm with quick connects for when the doors are off.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
post #3 of 4 Old 10-10-2001, 11:00 AM Thread Starter
helter
Jeep Chic replied:
Someone correct me if I am wrong, but,I believe the replacement door handles that are chromed have the metal parts on the inside mechanism.
When you say 'replacement door handles' I think you're thinking of 'outside door handles' so you can get into the vehicle from the outside - what I'm looking for is 'inside door handle' so I can get OUT of my Jeep - have you ever seen chromed inside door handles with metal hardware? If so - please point me there!
Or do the Chromed handles come with the rods and the piece that hooks to the inside door handle?
Any thoughts on any hardware I could use from a hardware store to replace these plastic pieces?
thanks,
Helter
92 YJ - 30x9.5 BFG
helter is offline
post #4 of 4 Old 10-11-2001, 05:44 AM Thread Starter
helter
Well - how about I get a clue - I mentioned that I had replaced this part once before - Well - I kept the old part. Each door handle has 2 of these little snap-prone plastic connectors - so my old part still has 1 good one(from the door lock switch). Of course - I needed someone else to point this out to me - after I fixed it with duct tape and put the door back together. I wonder how long the duct tape will hold? Once it goes - I realize now that I have 1 spare connector.
92 YJ - 30x9.5 BFG
helter is offline
need new inside door handle kylerobichaud Wrangler General Discussion 0 03-30-2009 02:08 PM
inside door handle joeyrossmiller YJ Wrangler Technical Forum 19 03-17-2009 01:26 PM
inside door handle wont open door alecmcmahon YJ Wrangler Technical Forum 2 07-30-2006 06:39 PM
inside door handle replacement buckydano TJ Wrangler Technical Forum 2 05-18-2006 04:58 PM
Inside door handle thecarman YJ Wrangler Technical Forum 3 11-05-2002 07:37 PM
