ins. cluster wire info - JeepForum.com
post #1 of 10 Old 12-04-2006, 09:44 AM Thread Starter
kenny kustom
I have been looking through my haynes manual trying to find some wire info on the cluster. My cluster is from a 94 yj. I am replacing the guages with a set of autometer. Short of tracing the board, does anyone have the wire colors for the cluster ?
kenny kustom is offline
post #2 of 10 Old 12-04-2006, 10:00 AM
jeep63
jeep63's Avatar
Black - Ground
White/Black - 12 Volt Power
Orange/Black - Illumination
Tan - Fuel Level Sender
Pink - Clock constant Power
Violet - Water Temp Sender
Light Blue - Oil Pressure Sender
I did this exact swap and I love it. I used Autometer Phantom II guages.
jeep63 is offline
post #3 of 10 Old 12-04-2006, 10:16 AM
mfalik
mfalik's Avatar
Hopefully one of these helps.
mfalik is offline
post #4 of 10 Old 12-04-2006, 11:05 AM
dadstoy
Ok mfalik, do that for the speedo and tach.
dadstoy is offline
post #5 of 10 Old 12-04-2006, 12:14 PM
mfalik
mfalik's Avatar
The first image has the speedo and tach.
MichiganTech Mechanical Engineer Alumni
1994 Wrangler Sahara - Jeep Project
2003 Dodge Ram 1500 (new truck)
2007 Mazda CX-7 (the new commuter car)
2005 Mitsubishi Lancer (Rear Ended - TOTALED)
1998 VW Beetle (SOLD)
1988 Jeep Cherokee Limited - (SOLD)
mfalik is offline
post #6 of 10 Old 12-04-2006, 02:45 PM Thread Starter
kenny kustom
i dont have have the connectors now. Any ideas on the wire colors ?
post #7 of 10 Old 12-04-2006, 02:54 PM
dadstoy
Duh..........thanks for pointing that out to me.
dadstoy is offline
post #8 of 10 Old 12-04-2006, 09:07 PM
Eriksm
Originally Posted by jeep63
Black - Ground
I did the swap with the Autometer Chrome Series gauges and had the same wire colors. I used like 3 wire diagrams to find all the colors. Fairly easy swap. I suggest the gauge pods to make installation a bit cleaner looking.
Eriksm is offline
post #9 of 10 Old 12-05-2006, 03:45 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
which gauge pod(s) install the cleanest and have the best fitment?
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #10 of 10 Old 03-21-2009, 09:46 PM
toneloc3131
im installing an autometer temp gauge as well. but i have a question. in the instructions it says that one wire goes to ground, the second wire goes to the sender and the third wire goes to the ignition. what color wire would be the ignition?
toneloc3131 is offline
Anyone ever mastered the 3 wire turn signal rewired to the 2 wire LED Rippers TJ Wrangler Technical Forum 28 06-08-2016 01:29 AM
speed sensor wire and reverse wire for aftermarket navigation system Stacydmcc JK Wrangler Technical Forum 1 11-06-2009 03:07 PM
Let's Play Guess the Wire Cluster!! Stauffeneker YJ Wrangler Technical Forum 62 11-19-2008 10:37 AM
Chev 350 engine swap could use wire info strd27 YJ Wrangler Technical Forum 5 08-10-2008 05:37 PM
2001 Guage cluster problem, not the usual cluster problem. glennv TJ Wrangler Technical Forum 2 08-16-2005 07:16 AM
