Injector Upgrade - JeepForum.com
post #1 of 4 Old 08-09-2011, 07:41 PM Thread Starter
Spuznick242
Injector Upgrade
Are these the correct injectors to swap in? I want to make sure before buying them. http://cgi.ebay.com/ebaymotors/Ford-...Q5fAccessories
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #2 of 4 Old 08-09-2011, 08:32 PM
jonzjeepyj
Yes they are correct. Look around and type in several different key
words. Ford is not the only one that used these 19lb injectors. They
are Bosch 19lb EV1 injectors. I found a Volvo on Ebay, that was a 5
cyl and purchased the set of 5 for 12.34 shipped to my door. Ford is
the most popular manufacture that used them but again, shop around.
My local pick and pull yard charges 5.00 each for these. 20.00 buck is
a whole lot better then 45.00 plus shipping.
There is no problem that can't be fixed if you throw enough money at it.
jonzjeepyj is offline
post #3 of 4 Old 08-10-2011, 03:56 PM Thread Starter
Spuznick242
But if I buy them for $50 and sell the other set of 4 that I'm not using to my other 2.5L buddies then it's like I'm paying what you paid, and helped a friend, I'm just going with these.
post #4 of 4 Old 08-10-2011, 11:48 PM
jonzjeepyj
Sounds good. You're on the right track. Just wanted to put that out there that
many autos use the Bosch Type III EV-1 19lb Injectors and Ford was the most
popular. Good luck with the purchase and install of your 19lb injectors.
Happy Trails,
John
Ford 19# injector upgrade in 4.0l kk491745 TJ Wrangler Technical Forum 54 07-06-2016 03:16 PM
Ford fuel injector upgrade Budke YJ Wrangler Technical Forum 2 03-27-2011 06:41 PM
Need help with 19# injector upgrade rmfab YJ Wrangler Technical Forum 2 11-02-2009 11:10 AM
Gas leaking around injector, o-ring or injector itself? hedrinbc TJ Wrangler Technical Forum 8 05-09-2007 09:13 PM
