info please!! dana 35 1330 to 1310 yoke swap? - JeepForum.com
post #1 of 13 Old 06-25-2011, 03:25 AM Thread Starter
troy.j
I need info fast. I F’ed up the wife’s jeep and she is P!SSED.
What is required to change a Dana 35 pinion yoke from a 1330 to the smaller 1310?
I know it’s smaller and weaker. I got a sye and shaft of eBay and didn’t do my homework. Now I have a shaft that won’t work without buying expensive conversion U-joints. I want to put the smaller yoke on and be done.
what can i get a yoke off from?
are the seals different?
Jeep is a 95 yj Sahara.
4.0
Dana 30/35 open SOA
Sye and shaft from eBay
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=370474773865&viewitem= &sspagename=STRK%3AMEWNX%3AIT
thanks
99 tj, 00 wj, 95 yj
...ask those who have bled of the cost of freedom and honor those who gave that others may have what we take for granted...
troy.j is offline
post #2 of 13 Old 06-25-2011, 06:06 AM
oldtime_ironman
Randy's ring and pinion
East Coast Gear Supply
Advance Adapters
Look all of them up online and then start making phone calls. Tho if it was me, I'd just get the conversion yoke.
oldtime_ironman is offline
post #3 of 13 Old 06-25-2011, 06:14 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Conversion joints were about 20$ at napa last time I bought one. And that was 1310-1350.
You could buy two joints for the price of a used yoke.
ratmonkey is offline
post #4 of 13 Old 06-25-2011, 06:24 AM
hesserdude07
there is a conversion ujoint that i use on my 1310-1330. it comes from a 70s ford truck, 4x4, rear axle joint... i think the last one i got at auto zone was less than $12.
Most any 'Good' parts store has a u joint conversion chart or atleast will know how to look them up. (just happens not to be my part stores)
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #5 of 13 Old 06-25-2011, 07:06 AM
SLADE
Originally Posted by troy.j View Post
I know itís smaller and weaker.
The 1310 joint has a higher operating angle than the 1330. The 1330 is only mildly stronger than the 1310, but will bind up and break sooner than the 1310.
Don't loose any sleep over the diference in strength. you won't be losing anything by going to the 1310.
It shouldnt be too difficult to find a second hand part, junkyard part for a Dana 35.
SLADE is offline
post #6 of 13 Old 06-25-2011, 07:21 AM
jeepinmichguy_
Just get a conversion joint, its cheaper than you think.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #7 of 13 Old 06-25-2011, 07:47 AM
SpikesHD
1987 YJ Wrangler
X2, our conversion joints are less than $20. You'll spend at least $40 on a new pinion yoke and have to wait on freight more than likely.
SpikesHD is offline
post #8 of 13 Old 06-25-2011, 08:03 AM
4.7stroker
Mapquest driveline and see if there is a shop local to you that has the parts you need.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #9 of 13 Old 06-25-2011, 08:07 AM
ZeroGravity
Another vote for conversion joint. But get two of them.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #10 of 13 Old 06-25-2011, 11:25 AM Thread Starter
troy.j
going to napa and check for the joint
thanks all for the help
99 tj, 00 wj, 95 yj
troy.j is offline
post #11 of 13 Old 06-25-2011, 12:31 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Precision 253 for solid steel cross.
Precision 353 for greasable hollow cross.
Napa will have those. Should be between 13$ & 18$.
post #12 of 13 Old 06-27-2011, 12:13 AM Thread Starter
troy.j
Picked up joints at Napa. They were 19 and change. I got two so we will have a spare on vacation. I kept the 1310 I pressed put for a spare to use in the CV.
99 tj, 00 wj, 95 yj
troy.j is offline
post #13 of 13 Old 05-24-2013, 02:23 PM
Towny72
Just wanted to add to this old thread in case somebody is searching the web and has the same issue.
I purchased a new Drive Shaft for my YJ after putting a SYE kit on. When I ordered the custom shaft I was away from the house so I had somebody measure the yoke for me. I did not do enough research and did not realize the YJ had a 1310 or a 1330 Yoke so while I got my lengths measured up I ignored the fact that I should measure the yoke as well. Turns out my friend did not measure the yoke correctly. Thanks to Jeepforum and this tread I was still able to get the new shaft in today and Ill be able to tool around a bit on the 3 day weekend.
The 1310-1330 Conversion U joint is a quick easy fix for anybody that has this issue. Just be ready to deal with the guys at the parts store telling you they do not make such a thing. The big chain stores did not help, but the guy with the old store and the old school parts book was able to get me what I needed and out the door in a few minuets.
Rust, Rust, Rust, and a lil more Rust.....
Towny72 is offline
1310 or 1330 u joints Jeeper_YJ YJ Wrangler Technical Forum 16 04-18-2010 01:02 AM
Dana Spicer 1310 and 1330 u joints aerojeeptj TJ Wrangler Technical Forum 9 03-30-2010 11:07 PM
1310 to 1330. HELP Imped TJ Wrangler Technical Forum 6 04-01-2009 11:36 AM
What style u-joint/yoke on D35? 1310,1330, 1350? greendot200200 TJ Wrangler Technical Forum 4 02-25-2009 07:33 PM
1310 to 1330 yoke for dana 35 jeepfury YJ Wrangler Technical Forum 12 01-10-2007 10:46 AM
