Infamous 4.0 Diesel - JeepForum.com
post #1 of 3 Old 08-13-2011, 06:17 PM Thread Starter
Skydmark1
Infamous 4.0 Diesel
So my 4.0 has that infamous engine ticking/tapping that makes it sound somewhat like a diesel. Its got over 200k miles on it (I just got it though). Seems to run pretty good but I'm planning a tune up and wanted some feedback from everyone on how to prolong this engine. First, does anyone know what causes this ticking tapping sound on these engines....I tried pulling the wire off each injector to see if any cylinder quieted down but it made no difference.
Specifically is there a certain weight oil I should use? Temps range -30 to 100F here in NH. What about spark plugs? Thought about trying a screamin demon coil and opening the spark plug gap but will that have ill effects on this engine?
Looking for input and opinions about this!! I want to max my usable engine power and efficiency but also want to keep it running as long as I can!
-2013 JKU Sport, bone stock, Auto with 3.73's
-1998 ZJ Laredo, 4.0 42RE Selec-Track, 30" M/T tires
Skydmark1 is offline
post #2 of 3 Old 08-13-2011, 06:42 PM
Noltz
YJ Wrangler
My best luck with killing tapping noises from lifters (which is usually the cause of tapping from 4.0's) is Seafoam engine treatment in the crank case. I replace 1/4 of the engine oil with seafoam, up to a max of 1L, and go drive it for 20-30 minutes. Then with everything nice and hot (and crap is suspended in the oil) I change the oil and filter.
Oil weight, 10w30 in the summer, 5w30 in the winter, but you'll get a lot of opinions on that. That's what I run. A good tune up (plugs, wires, cap and rotor, coil if needed, set timing) will provide max power and fuel efficiency. Proper maintenance, oil changes and air filters will provide maximum life.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #3 of 3 Old 08-13-2011, 08:26 PM
chicalibro3
I replaced one quart of oil with a quart of Marvel Mystery Oil. I use 10w-30 high mileage all year. That quieted my engine substantially. I also use the Bosch copper plugs in it. No platinum.
Nobody is gonna make it out alive. Might as well have some fun.
chicalibro3 is offline
The Infamous Jeep Wave tribalcross Wrangler General Discussion 152 02-27-2012 02:23 PM
The Infamous code 51????? sutbag TJ Wrangler Technical Forum 5 01-17-2010 07:29 PM
Fixing the infamous TrailJammer whistle ***write up*** Squeeky TJ Wrangler Technical Forum 12 01-14-2008 05:30 PM
The Infamous Manifold Wynne TJ Wrangler Technical Forum 7 12-26-2007 06:25 AM
The infamous Check Engine light... Darkus TJ Wrangler Technical Forum 1 12-24-2003 08:59 AM
