Increasing cooling system capacity - JeepForum.com
post #1 of 13 Old 05-29-2013, 04:54 PM Thread Starter
shinigami
I had a wild idea that i need opinions on.
I currently have a 357ci v8 under my hood with a 3 core 4.0 radiator and mercury MK VIII E-fan taking the heat load.
During normal driving my temp gauge normally reads a healthy 190*. however when towing or constantly going up large hills my coolant exceeds 210* to the point of over boiling.
I was thinking of getting a small air tank of about 2 gallons and mounting it under the body out of the way to run coolant through and to increase the cooling system capacity and hopefully solving this issue, possibly getting a small oil cooler out of the junk yard to mount inline on the frame. all of this running off of the heater lines since I am not running a heater at all.
Would this work or is there any better ways with out a radiator swap?
Originally Posted by jmathis3 View Post
lots of hair pulling, tool throwing, beer drinking, swearing, and eventualy it will start. haha good luck.
I LOL'd
I.Y.A.A.Y.A.S.
shinigami is offline
post #2 of 13 Old 05-29-2013, 05:25 PM
jbolty
jbolty's Avatar
turning on the heater makes a pretty big difference if you're running a little hot but of course you start sweating bullets. I have considered adding an extra heater core under the battery tray with some sort of fan. Maybe cut a hole thru the side of the fender to exhust the air.
An engine oil cooler is a nice add on as well.
jbolty is offline
post #3 of 13 Old 05-29-2013, 05:36 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Is the electric fan you have a 2-stage fan? High and a Low or a constant speed? Having an option to increase the fan speed may help some.
I like the idea of an oil cooler as well. Usually you can find kits that have everything you need and that will increase your oil cooling and oil capacity (somewhat) as well.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #4 of 13 Old 05-29-2013, 06:08 PM Thread Starter
shinigami
its a 2 stage fan. I do plan on adding an oil cooler in the future but my thought is that the motor was designed to have a 17.5qt cooling system and right now is at about a 13qt system so adding the extra capacity will bring it up to the motors standards a bit more
I LOL'd
I.Y.A.A.Y.A.S.
post #5 of 13 Old 05-29-2013, 06:12 PM
SuperMidget
Is your fan a single or dual fans? A good aluminum radiator and efan setup should be more than enough to cool it
SuperMidget is offline
post #6 of 13 Old 05-29-2013, 06:18 PM
Louie4
I'm no expert but I don't see how adding a reservoir inline will help. It seems like the coolant will just heat up and sit there. The heat needs to be removed from some sort of heat exchanger (radiator, heater core). Larger radiators with more cores increases capacity and surface area which will dissipate more heat.
I like jbolty's idea of adding an additional heater core with a small fan. I've seen a Cherokee that mounted a heater core and small fan on the hood. You could also add louvers around the engine compartment too.
Just my 2 cents though.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #7 of 13 Old 05-29-2013, 06:42 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Your V-8 obviously needs more cooling capacity then you are providing using a stock 4.0 radiator. Why don't you add the external oil cooler to cool the oil? That will bring engine temperatures down also.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #8 of 13 Old 05-29-2013, 06:59 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Well there is your issue ! Get a Radiator designed for V8 swaps
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #9 of 13 Old 05-29-2013, 06:59 PM
95YamJam
Does this have an auto trans? If so are the trans cooler lines using the rad for cooling? I would bet that where your extra heat is coming from if this is the case. If not then..... Bigger rad/make sure your rad is clean. I had a ton of mud packed in mine and it ran a bit warm.
My build: http://www.jeepforum.com/forum/f22/95-yam-project-1527472/?highlight=
95YamJam is offline
post #10 of 13 Old 05-29-2013, 08:01 PM
jay-h
Originally Posted by Louie4 View Post
I'm no expert but I don't see how adding a reservoir inline will help. It seems like the coolant will just heat up and sit there. ....
You are correct. Increasing the coolant will only help marginally (take a little longer to overheat).
What is needed is cooling capacity. Larger radiator, better fan (less effective because at speed the fan is not doing much anyhow). Cooling the oil is CERTAINLY a good thing, but larger radiator is the only way out of this one.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #11 of 13 Old 05-29-2013, 08:41 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Do some reading on the three quotes.
Anticanman is offline
post #12 of 13 Old 05-29-2013, 09:30 PM Thread Starter
shinigami
Radiator barn had this radiator I have as the same dimensions and cores as the v8 swap radiator except for hose placements for chevy, my ford motor needs the stock hose placements. I will add a oil cooler when funds allow, I rarely get to the point of overheating except when under alot of load, so hope it works. no, I have a manual but the radiator has a trans cooler built in I use for power steering.
I LOL'd
I.Y.A.A.Y.A.S.
post #13 of 13 Old 05-29-2013, 09:34 PM
czjeeper
I had the same problem until I went with a nice big aluminum radiator.
Many of the "V8 swap" radiators are the 4.0 radiator with the necks modified. They don't work right a lot of the time.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
