increase towing capacity - Page 2 - JeepForum.com
post #16 of 62 Old 08-21-2013, 07:49 AM
hbflash
Jeep Driver
hbflash's Avatar
Originally Posted by XJ93 View Post
A 2000# tow rated hitch adds that much to the GVWR.
Kind of. Your GVWR calculation needs to consider the tongue weight though. The weight on the trailer axles is not included in GVWR. The GCWR does include the weight your pulling, which I can't seem to find for the YJ. It may be limited by your license plate type?? Maybe someone can clarify.
Originally Posted by 140mower View Post
You will be breaking the law, but probably not as bad as the Kid texting behind the wheel or the soccer mom putting on make-up. or the fellow heading home after a few beers from the bar. Pick your poison, we all break laws to some degree.
I totally agree. I speed every day on my way home from work. I just didn't want anyone to think that putting 1 ton axles and brakes on their YJ was going to make it legal to pull a 5,000 LB trailer.
It's a calculated risk you may be willing to take. I just don't want to be the person that gets into a crash that's 100% not my fault, but have an insurance company refuse the claim because I was legally overweight.
hbflash is online now
post #17 of 62 Old 08-21-2013, 07:58 AM
pasinbuy
Pasinbuy, first I have never seen a "bumper ball" on a YJ, secondly I am not sure what kind of hitch you have, if it mounts to the rear crossmember I have no doubts that it is a hairy job to tow. My hitch mounts to the frame, and I have pulled 1500# without issue. I drive slower, pay way more attention to the roads and other drivers. I also replace my brakes well before they need it so I have no issues with that. I would hope the o.p. also does frequent maintenance on his brakes.
I am talking about the ball that is mounted to the bumper that is really not designed to tow and comes with a warning concerning it. Why bumpers have the ball attached is a mystery to me. The only safe way to tow is with a separate receiver on all vehicles.
Second the cross member is the frame and what my hitch receiver is attached to. I would have to guess that is where your receiver is attached also. Or post a picture I would like to see how you may have attached your receiver.
pasinbuy is offline
post #18 of 62 Old 08-21-2013, 09:06 AM
140mower
My experiences with the insurance companies has been that of getting screwed no matter what the cause or reason, they can afford way better lawyers than I can and are willing to do most anything to escape payment. I hate to say it, but if you're breaking any law or even bordering close to it, a good lawyer's going to shred both you and your wallet, sad but true. Politicians, lawyers, and insurance agents all fall into the same category in my mind and we used to scrape that out of the cow barns and into a pit back on the farm.
If it wasn't done the hard way, I didn't do it.
140mower is offline
post #19 of 62 Old 08-21-2013, 09:14 AM
superj
preach on brother, preach on /\
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #20 of 62 Old 08-21-2013, 09:33 AM
Reno72
So true, but that is because too many roll over for these scum, after 6 years through the ringer the court of appeals ordered "flo" to write me a 7 figure check, I had better lawyers, but even more, I was right.
Reno72 is offline
post #21 of 62 Old 08-21-2013, 10:13 AM
pasinbuy
You are so right. We are all screwed!
pasinbuy is offline
post #22 of 62 Old 08-21-2013, 01:17 PM
XJ93
Pasinbuy, my receiver does not attach to the rear cross member, which is not frame it's a cross member which is thinner material. My receiver actually bolts to the frame rails via 6 grade 8 bolts on either side, the way it should be done. What you call a "bumper ball" is the type seen on pickup trucks, which I have never seen on a YJ.
XJ93 is offline
post #23 of 62 Old 08-21-2013, 01:47 PM
pasinbuy
Here is one of many receiver bumpers http://www.4wheelparts.com/Bumpers-T...FWho7AodkzUAng This is what I was referring to, I may not have explained it the right way.
I have not noticed where a Yj had the receiver bolted to the side frame rails. Show me a picture of your setup.
Fyi; Your rear cross member is part of your frame. Yes it is thinner on our Yj that is why I beefed up mine to be more comfortable towing.
pasinbuy is offline
post #24 of 62 Old 08-21-2013, 03:02 PM
XJ93
Yes the rear cross is PART of the frame, but is not in any way preferable to mount anything to. I can't take pictures of my set up as it's all up in the frame, kinda hard to take pictures of it without dropping the tank, and I am not doing that for some pics. I can tell you, again, that my hitch is BOLTED TO THE FRAME RAILS VIA 6 GRADE 8 BOLTS ON EITHER SIDE. Not sure how much more plain I can say that.
XJ93 is offline
post #25 of 62 Old 08-21-2013, 03:21 PM
XJ93
Besides, every single outlet that sells receiver bumpers say none of them are tow rated. You should do research and contact the manufacturer themselves and ask about tow rating. Even the cheap Smittybilt bumper is tow rated for 2000# towing with a 300# tongue weight.
XJ93 is offline
post #26 of 62 Old 08-21-2013, 04:26 PM
Norcal_chris
Norcal_chris's Avatar
I dont even trust the stock crossmember to hold a plain bumper. Even if you bolt some sort of plate to it, it is still a thin peice of metal butt welded to the frame.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #27 of 62 Old 08-21-2013, 05:00 PM
pasinbuy
Not a problem.
You do know that writing is caps is yelling and bolding your print is screaming? I do not see how you can mount a receiver to the frame rails. That said, please do not yell at me again. I have no intention to reply to you.
pasinbuy is offline
post #28 of 62 Old 08-21-2013, 05:07 PM
pasinbuy
Here is a picture of my rear cross member showing that I welded a 3/16 piece of steel to it . I templated the rear cross member with cardboard and took it to a welder who made the piece for me at a cost of $45.00. I then attached it by welding it in all the way around. You can also see in the picture the thickness of my hitch receiver that is a separate part from my bumper. With eight grade 8 bolts to the cross member/frame.
pasinbuy is offline
post #29 of 62 Old 08-21-2013, 05:18 PM
Norcal_chris
Did that plate get welded to the frame as well?
The issue is the crossmember is only welded in a small spot on either side of the frame. About a 1.5in strip on either side. I had a spare tire carrier with a 35in tire and a hi lift and gascan and after a few months the welds were cracked on one side.
post #30 of 62 Old 08-21-2013, 05:23 PM
pasinbuy
I looked at mine and I thought it looked pretty good. (Back then.) I will have to recheck it to see if I should do some added bracing.
Thanks for the heads up.
I do little to no towing with my Yj. I have a 1 ton, V10 for that. As stated towing with the Yj is dangerous. Our brakes suck.
pasinbuy is offline
