Inconsistent Starter Grind - JeepForum.com
post #1 of 2 Old 07-29-2002, 03:02 AM Thread Starter
ScotZ
American to the Bone
ScotZ's Avatar
Every once in a while the starter on my 1990 6 cyl. YJ grinds against the flywheel. Not very often, just enough to be annoying.I have had the starter off twice and could not see any problems. Has anyone else had this type of problem? I can live with it happening once or twice a month as it always starts the next try.This has been happening for over a year.. Just wondering !!! Thanks for your time and effort.....Scot
ScotZ is offline
post #2 of 2 Old 07-29-2002, 08:00 PM
moabster
moabster's Avatar
2011 WK
I've had similar problems before. I can think of a couple of things you may check.
1. Broken tooth on flywheel gear. You only hit it once in awhile.
2. Weak starter solenoid. Does not fully engage starter motor with flywheel.
Next time you get the grinding pull the starter before you start the engine. If a gear tooth is chiped or broken it should be visable.
For the second case, pull the starter and see if the edge of the starter gear is worn where it first engages with the flywheel. This could indicate your starter is not fully engaging with the flywheel.
HTH
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
Inconsistent Rattle ryman522 TJ Wrangler Technical Forum 8 01-25-2010 08:32 PM
starter grind/slips in park, but not it neutral. jaminb YJ Wrangler Technical Forum 7 11-27-2009 07:29 AM
Idle Inconsistent Gappy TJ Wrangler Technical Forum 6 03-14-2008 07:30 PM
New Problem - Starter Grind & Screech ceejay64 YJ Wrangler Technical Forum 5 04-15-2007 04:25 PM
inconsistent clutch bousquet12 TJ Wrangler Technical Forum 0 07-19-2005 06:33 PM
