I'm stumped, bad sputtering - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > I'm stumped, bad sputtering
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 04-08-2007, 09:54 PM   #1
dcafaro
I have a bad sputter of my engine when its cold. Once it's at operating temperature it smooths out. It's a total loss of power though for about 5 seconds intermittently until it warms up. I've already replaced the cat, the TPS, The IAC, and the fuel filter. Can't be the cps because it starts only things left are the fuel pressure regulator and the 02 sensor. Am I missing something else? it's a '94 4.0??
88 Sahara Black, 210000 (6/12/06)
3.5 inch DC suspension lift (CJ springs so a bit taller),
1.25" shackles, 1.25ish body lift, 35" BFG ATs,
stinger type front bumper custom rear.
TJ soundbar with custom speaker set up
engine 94 4.0. ~ 70, 000( head and block 98 grand)
axles 4:11 trans Automatic TF999
dcafaro is offline   Reply With Quote Quick reply to this message
Unread 04-08-2007, 09:58 PM   #2
joe's_yj
Try plugs, rotor,cap,and wires?
joe's_yj is offline   Reply With Quote Quick reply to this message
Unread 04-08-2007, 10:10 PM   #3
dcafaro
sorry already did those too.
Unread 04-08-2007, 10:11 PM   #4
joe's_yj
hmm. Have you checked your timeing?
Unread 04-08-2007, 10:28 PM   #5
dcafaro
thought about it, but without any major engine issues timing really shouldn't go off. The engine only has a bout 85000 miles on it. I have also already done the MAP sensor too.
Unread 04-09-2007, 04:17 PM   #6
dcafaro
to the top, any other suggestions?
Unread 04-09-2007, 06:17 PM   #7
Jeepinjon
Yeah, I had something similar. Turned out to be the o2 sensor. Hope that helps.
Jeepinjon is offline   Reply With Quote Quick reply to this message
Unread 04-09-2007, 06:51 PM   #8
jeepinjc
My only guess is mabe a very small vaccum leak and when it is cold the leak opens up but when it warms up the leak seals itself??
Jason
ps: Just like a woman you gotta warm her up first
Blue 93' YJ, 4.0, 5spd, skyjacker 4" lift, crager simulated beadlocks w/33" bfg muds, skyjacker swaybar disco's, dana 30/35 w/ 4:10's, skyjacker t-case drop, and many mods to do yet
Jeep Drivers who dig COUNTRY music member #13
jeepinjc is offline   Reply With Quote Quick reply to this message
Unread 04-10-2007, 05:29 PM   #9
dcafaro
I'll change the 02 anyway as I have yet to do that anyway with this engine, but I was wondering about the fuel pressure regualator. Any telltale signs when that things on the blink? Injectors themselves should be fine as it is only a problem when cold.
Thankfully for me the little lady warms up a lot quicker than the Jeep
Unread 04-10-2007, 06:19 PM   #10
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
X2 on the vac leak. My 94 XJ had the same issue and it was a vac line.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote Quick reply to this message
Unread 04-10-2007, 06:37 PM   #11
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
you just said it was temp related and yet you haven't mentioned either of the two temp sensors? coolant temp and manifold air temp come to mind. get the meter out and check their resistance with the engine cold. timing is all computer controlled so it can be off, but only because you have a bad sensor.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline   Reply With Quote Quick reply to this message
Unread 04-11-2007, 01:08 AM   #12
dcafaro
where is the MAT sensor on this engine? I did have a loose wire on the front temp sensor that was causing my gauge to bounce around but I tightened that up and the gauge at least is fine now.
Unread 04-12-2007, 06:12 AM   #13
dcafaro
the winner is... a dry rotted elbow on the line to the fuel pressure regulator. 2.30 piece of tube and all is well. funny how we find things by accident, while looking for something more complex...
  • stumped - TJ Wrangler Technical Forum (4 replies)
  • I'm Stumped..... - YJ Wrangler Technical Forum (21 replies)
  • Stumped... - YJ Wrangler Technical Forum (7 replies)
  • I'm stumped - YJ Wrangler Technical Forum (17 replies)
  • Stumped - YJ Wrangler Technical Forum (4 replies)
