I'm in over my head (and need your help) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > I'm in over my head (and need your help)
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-06-2014, 08:18 PM   #1
Dwarf
1987 YJ Wrangler
Hey jeepers,
So, I decided to tangle with the computer delete today and am acutely aware that I'm up the creek.
Background: 87 with a 76 block and carb. I'm looking to clean the 30 miles of wasted copper out of the cab and engine compartment.
I've (hopefully) attached 3 images. What I have found is that half the wires from the engine side of the fuse block run back through the firewall to the computer. I have a twisted pair of orange/purple wires running from the computer to the dizzy. The dizzy has a vacuum advance.
Questions:
What do I do with the purple/orange wires to the dizzy?
Can I just cut the rope of wires from the computer?
Dwarf is offline   Reply With Quote Quick reply to this message
Unread 04-06-2014, 08:24 PM   #2
dancytron
Well, if it is was a 1987-90 4.2 liter engine, then yes, after you do the Nutter Bypass you can cut the big bundle of wires going to the computer, push them through the firewall and follow them and remove them. What you got is a little different so I am not sure that answers your question.
Here is a good link on how to do the Nutter bypass on a 1987-90. http://www.jeepforum.com/forum/f8/ho...bypass-522262/
This might help too. http://home.sprynet.com/~dale02/list.htm
dancytron is offline   Reply With Quote Quick reply to this message
Unread 04-06-2014, 09:58 PM   #3
Old4X
1990 CJ7
Follow the instructions for the Nutter mod. You need a twisted wire pair running from the distributor to the ICM. The other wire in the 3 wire harness from the distributor should go to a good ground, not needed by the distributor itself, it is the ground for the ICM.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
Unread 04-07-2014, 07:11 AM   #4
Que89YJ
Just sayin'
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 04-07-2014, 07:59 AM   #5
roadyrob
1987 YJ Wrangler
if it was me I'd get a HEI distributor and get rid of 90% of that mess.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is online now   Reply With Quote Quick reply to this message
Unread 04-07-2014, 08:28 AM   #6
Dwarf
1987 YJ Wrangler
Don't the HEI dizzys cause issues with the hard metal gears?
Thanks for the replies the nutter link helped a lot. I cut the "computer" out last night and have laid out the wiring neatly, so I feel good about that.
There were two relays that were mounted to the battery tray support, along with all the diagnostic sockets. What are they for?
Unread 04-07-2014, 09:19 AM   #7
sardog211
Originally Posted by Dwarf
Don't the HEI dizzys cause issues with the hard metal gears? Thanks for the replies the nutter link helped a lot. I cut the "computer" out last night and have laid out the wiring neatly, so I feel good about that. There were two relays that were mounted to the battery tray support, along with all the diagnostic sockets. What are they for?
If you go with a Hei look into CRT been ruining one for about year now and very happy with it. I did the same thing and gutted the computer and wires under hood, all the stuff by the battery can go, just make sure you label starter relay wires, aside from that keep your oil pressure wire, temp wire, and your voltage reading stuff, basically just your instrument cluster inside. I had a mess like yours, and had to get some assistance with the starter wires.
sardog211 is offline   Reply With Quote Quick reply to this message
Unread 04-07-2014, 09:20 AM   #8
Old4X
1990 CJ7
Lots of problems with the HEI units, but for the electrically challenged, they are easy to install and wire up.
Unread 04-07-2014, 09:46 AM   #9
roadyrob
1987 YJ Wrangler
I'm definitely electrically challenged, I've also run a HEI for over 5 years with 0 problems. only the cheap ebay junk wreck cams.
not sure what lots of problems are, please explain.
Unread 04-07-2014, 10:23 AM   #10
Old4X
1990 CJ7
Poor heatsink for the ICM leads to shortened life.
Inside the distributor is the worst location for the ICM, as no cooling air is available, and ionized air shortens component life and leads to arc-over of ignition energy.
Poor seperation of coil from grounded distributor body, causing crossfires and shorts/burn through of components.
Poor cooling of coil due to location.
None of the HEIs sold have the correct advance curve for the AMC 6 cyl engine, they are designed for the GM motor.
There is a reason the self-contained design was dropped by GM and also never adopted by other manufacturers, it is a flawed, stop-gap design.
Unread 04-07-2014, 10:43 AM   #11
dancytron
Assuming it is the same as mine, one of the relays is for the manifold heater. You want to keep that if you can. The other is (if I remember correctly) for the pulse air solenoids. You can get rid of that one.
Just from reading on the forum, the hard metal gears problem with HEI is only the cheap ones. But there isn't any good reason to replace a perfectly good working part unless you have extra money to throw around for no good reason.
Unread 04-12-2014, 08:56 AM   #12
Dwarf
1987 YJ Wrangler
Alrighty, I got in touch with Dan and should have a new dash soon. Till then, I need to get this mess in order!
Unread 04-12-2014, 03:03 PM   #13
Dwarf
1987 YJ Wrangler
I can only upload one at a time
Unread 04-12-2014, 03:07 PM   #14
Dwarf
1987 YJ Wrangler
Does anyone have the part number to the DUI hei setup? It seems there are no gm 6 cyl with iron gears that I can find.
Unread 04-12-2014, 03:36 PM   #15
roadyrob
1987 YJ Wrangler
heres one on summit, lot of money when the crt hei works fine for 150 less.
http://www.summitracing.com/parts/du...ions/make/jeep
