im holding a gun to my head - Page 5 - JeepForum.com
post #61 of 64 Old 08-14-2011, 10:44 AM Thread Starter
riverhippy
WOOHOO!!!! took jeep to the beach yesterday!! the two main problems that were at issue were the head gasket and the cps, both give very similar symptoms. After i fixed the head gasket, the problems continued till i tracked down a wiring prom in the cps....thanks for all the help guys!! you f**king rock!!!
riverhippy is offline
post #62 of 64 Old 08-14-2011, 10:45 AM Thread Starter
riverhippy
im coding 23 still and have already replaced the sensor. is it the ecm or a wiring prob? im assuming there is a short.
post #63 of 64 Old 08-14-2011, 12:50 PM
oldtime_ironman
It could also be an "open" meaning a broken wire. Even if a wire looks OK on the outside it can still be broken on the inside. So you're gonna have to check for continuity between the CPS connector and the ECU.
You already did the head gasket, so now yer down to just this one thing.
Grats on the beach!
oldtime_ironman is offline
post #64 of 64 Old 08-15-2011, 10:05 AM
Que89YJ
Did you do the battery reset after you repaired it? You need to pull the battery connection for a long 10 count to clear the fault codes.
Que89YJ is offline
backfiring , help please , loss of power , sputters , YJ
Sway bar not holding Vic99TJ TJ Wrangler Technical Forum 7 06-22-2011 07:14 PM
How are your Moabs holding up? vtx531 TJ Wrangler Technical Forum 10 10-12-2009 09:20 PM
E-brake not holding..... primus TJ Wrangler Technical Forum 19 07-20-2006 05:09 AM
Holding flag nut...? thejafe TJ Wrangler Technical Forum 13 11-06-2005 06:36 AM
Holding down the hard top??? spark plug YJ Wrangler Technical Forum 11 01-29-2005 12:07 PM
