im holding a gun to my head - Page 3 - JeepForum.com
post #31 of 64 Old 08-04-2011, 10:24 AM Thread Starter
riverhippy
how do i attach pics?
riverhippy is offline
post #32 of 64 Old 08-04-2011, 10:38 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by Que89YJ View Post
He doesnt need the cat but everything else he does. I know he's around my area and I would give him a hand if I had a general idea of where he's at.
Federal law (2500$ fine) and jeep forum rules state he needs a cat.
And these chuckle heads dont need pics of your girl...lol
ratmonkey is offline
post #33 of 64 Old 08-04-2011, 10:39 AM Thread Starter
riverhippy
im in troy
post #34 of 64 Old 08-04-2011, 11:39 AM
Que89YJ
You can attach pics with the little paper clip in the box you type in. Troy is close by on my way home from work. I'm in Auburn Hills at the Tech Center. If you need help doing the head gasket let me know. I'll be back in town Monday. Good luck.....Remember the pic of the GF.
Que89YJ is offline
post #35 of 64 Old 08-04-2011, 01:08 PM Thread Starter
riverhippy
okeedok...anyone have an experience like this? when i hit a bump, the jeep hesitates....almost to backfire.
post #36 of 64 Old 08-04-2011, 01:10 PM Thread Starter
riverhippy
there is no paperclip....i guess i dont have enough posts yet. i tried to attach to my profile and it didnt work....ill try to make it my avatar pic.
post #37 of 64 Old 08-04-2011, 02:38 PM
oldtime_ironman
Yeah Que is the man when you got electric and vac probs. I kinda snuck in the back door and kept posting until I had enough for pics which is very rare for me. I have family out there in Mich (ann arbor and bay city) but its been a while like 10 yrs. Gonna have to hook up with you guys if I ever get a chance. Usually I pass thru the QEW from Buffalo into Detroit. I was into fab and welding for a living till I got disabled but I can still do a bit.
oldtime_ironman is offline
post #38 of 64 Old 08-04-2011, 02:43 PM
MightyLampshade
1979 CJ7
This would *appear* to be the picture you're trying to post based on your gallery?
Originally Posted by Keith
Let's make fun of him for being assaulted by chicken so he can claim emotional distress.
MightyLampshade is offline
post #39 of 64 Old 08-04-2011, 02:49 PM
oldtime_ironman
Yeah I had that a while. Anytime it got off level, it would hesitate, sputter, pop and bang. Main thing is the fuel pump assuming that you had at least 1/2 tank good lines and filter. pressure regulator wouldn't hurt either. I wound up changing the whole thing after a real bad night, and you have to admit that these things are like 20 yrs old. Took me like 5 hrs to get home. I recommend that you check it out before it bites you.
post #40 of 64 Old 08-05-2011, 12:06 PM Thread Starter
riverhippy
i still get the sputtering when the fuel pressure is solid. is there another test for fuel pump?
post #41 of 64 Old 08-05-2011, 12:08 PM Thread Starter
riverhippy
It was suggested i get an ecm from the junk yard...which im gonna do. i know that the cherokee will work, what are the models years and engine sizes that i can swap the ecm with?
post #42 of 64 Old 08-05-2011, 12:09 PM Thread Starter
riverhippy
yea...but the pic was too big, her legs are great tho the only reason i post her pic is so everyone understands the need to fix the jeep and take my girl to the beech
post #43 of 64 Old 08-05-2011, 12:11 PM Thread Starter
riverhippy
i bought it w no cat...the rest of the bypasses were to narrow the prob down. seems the codes im getting are b.s. i replace the part and it still codes...all things are pointing to the ecm. is there any way to test it other than a replacement?
post #44 of 64 Old 08-05-2011, 12:40 PM
GrantYJ
If you know somebody who has an ECM that you could try; however, your description sounds exactly like what mine did when my coil went out. It would run great for a few minutes (in the dead of winter) and then go straight to crap. It throws all the codes because it is experiencing those issues (due to little or no ignition).
Think about it, your O2 sensor pops a code because there is fuel in the exhaust that isn't burned... because it was never ignited.... because you aren't getting spark.
If you've got fuel pressure (which normally indicates that you're getting fuel), and you have compression, then you're probably not getting spark. Toss a spark plug test light on (you can get one for just a few dollars) and let your Jeep idle until the problem happens again. When it starts bucking, if you're getting no light or intermittant light, you'll at least be able to narrow it down to ignition.
And if I can be honored to speak on behalf of the chuckle heads, the picture of the girlfriend definitely doens't hurt.
GrantYJ is offline
post #45 of 64 Old 08-05-2011, 10:56 PM
monkeyhouse
definitely get a cat on there...and honestly, if a girl like that liked me, i don't know that i could have the intestinal fortitude to say go away. hope things work out my friend.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
backfiring , help please , loss of power , sputters , YJ
Sway bar not holding Vic99TJ TJ Wrangler Technical Forum 7 06-22-2011 07:14 PM
How are your Moabs holding up? vtx531 TJ Wrangler Technical Forum 10 10-12-2009 09:20 PM
E-brake not holding..... primus TJ Wrangler Technical Forum 19 07-20-2006 05:09 AM
Holding flag nut...? thejafe TJ Wrangler Technical Forum 13 11-06-2005 06:36 AM
Holding down the hard top??? spark plug YJ Wrangler Technical Forum 11 01-29-2005 12:07 PM
