I'm guessing here but I don't think it's supposed to do that - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > I'm guessing here but I don't think it's supposed to do that
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 03-24-2010, 05:49 PM   #1
Reverb
I'm guessing its a bearing, but I can't find it on morris 4x4. Anyone know what it's called. The steering box is at the other end of that rod on the left and after the knuckle the right shaft goes to the steering wheel.
Reverb is offline   Reply With Quote Quick reply to this message
Unread 03-24-2010, 05:53 PM   #2
Reverb
Wait... is it the column bearing?
Column Bearing Kit*4487696K by the Jeep Specialists | Morris 4x4 Center
Unread 03-24-2010, 05:53 PM   #3
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
This should help:
http://www.jeepforum.com/forum/f12/r...-my-yj-609628/
Joe Dillard is offline   Reply With Quote Quick reply to this message
Unread 03-24-2010, 08:26 PM   #4
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Yep column bearing is shot. See above write up.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote Quick reply to this message
Unread 03-25-2010, 09:59 AM   #5
Fernando
1987 YJ Wrangler
This may help
http://www.jeepforum.com/forum/f12/l...t-pics-741968/
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline   Reply With Quote Quick reply to this message
Unread 03-25-2010, 12:57 PM   #6
WhiteYJLA
I just went through this replacement recently. The writeup is nice if you can get your gearbox unbolted from the frame. My '92 was too rusted to move those bolts. Also my steering shaft was too rusted at the collapse section to move it down that way. I ended up having to unbolt the top knuckle and pull it out through the upper steering column. I can give you instructions if you have to go that route.
WhiteYJLA is offline   Reply With Quote Quick reply to this message
Unread 03-25-2010, 04:37 PM   #7
Reverb
Thanks for the replies all.
One question: in my vid on the short shaft to the steering wheel - that lip on the shaft - is it whats left of the bearing? If not how do i get the new bearing on there?
Unread 03-25-2010, 05:00 PM   #8
rustywrangler
I am about 99% certain that is part of the old bearing/bearing housing. Should come apart fairly easily once you tear down.
Unread 03-25-2010, 05:50 PM   #9
Reverb
Ok thanks dude. I'll get to it next week as soon as the bearing arrives.
Unread 03-25-2010, 08:19 PM   #10
YJ Ynot
Yeah its spoda do that it helps fight death wobble...
TOMMY
1994 YJ
4inch Suspension Lift, 35x15x14,2.5
I'll stop procrastinating tomorrow...
YJ Ynot is offline   Reply With Quote Quick reply to this message
Unread 03-25-2010, 08:31 PM   #11
Reverb
Well I don't really steer it at the moment - I kinda aim it in the general direction.
Unread 03-26-2010, 03:07 PM   #12
WhiteYJLA
Before I fixed mine it was like driving a school bus on open gravel. There was a lot of praying on the highway.
Unread 04-02-2010, 02:25 PM   #13
Reverb
Looks like I'm in the same boat as WhiteYJLA - my bolts are too rusted on the box and the sliding part is stuck solid. Anyone got any ideas?
Unread 04-03-2010, 03:00 PM   #14
Reverb
Well, I snapped two bolts off the pump so it's now running with half of them - and the PO welded the bracket to the body so it looks like I'm going to have to cut the bracket off and remove (snap) the other two bolts and replace them anyway. So I'm going to get a new telescopic rod while I've got the pump off and grease the hell out of it. Just for the hell of it I'm going to take off the steering wheel and whatever is under it and do the top bearing too. Then I can replace the wiper stalk that the PO broke and fix the turn signal cancel thats broken too.
