Im baaaack - JeepForum.com
post #1 of 6 Old 08-24-2011, 08:18 AM Thread Starter
wanabejeeper
1987 YJ Wrangler
Im baaaack
hey everyone, been awhile. After completing a new engine install and tranny rebuild to my 87yj (son blew the original motor) and installing same I discovered that I had stupidly installed the torque converter to the engine flexplate and then installing tranny to engine... (like I would a clutch to a flywheel) this resulted in me unable to turn the engine by hand.
Long story short I'd pulled everything except the engine back out and it still wont turn. I pretty much threw my hands up and walked away.
jeep has sat in my garage for about 2 years now and I'm about to start on the engine. I intend to pull the engine, put it back on the stand, pull the oil pan and see whats wrong in the bearings. Ive checked the tranny and it appears to be ok, nothing wrong with the pump, the converter slides in and seems to engage the pump ok. So hopefully theres nothing wrong with the tranny. I may have the shop look it over just in case.
I plan to start in a couple weeks.
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #2 of 6 Old 08-24-2011, 08:34 AM
Que89YJ
Make sure you spin that oil pump up before you try and crank it. That upper end will be dry as a bone after setting around that long. Get some oil up there:
http://www.jeepforum.com/forum/f12/o...-tool-1020455/
Que89YJ is offline
post #3 of 6 Old 08-24-2011, 08:51 AM
oldtime_ironman
Could be they sold you the wrong size of bearings. Happened to a buddy of mine once, they gave him a whole new crank and bearings and everything a week later on warranty. That was the fastest engine build I ever did, a Chevy 350. Tore it down on Friday, he drove it to work on Monday.
oldtime_ironman is offline
post #4 of 6 Old 08-24-2011, 10:58 AM Thread Starter
wanabejeeper
1987 YJ Wrangler
Engine is a purchased re-man long block. I will def prelube if I ever get that far. There was a thread back a while ago that had a similar problem and the issue was with a bearing. I may just climb under and drop the pan rather than undoing all of the top end stuff I have bolted on and pulling the engine... wont have to rent a hoist again either.
87 YJ The Original!
My build thread
post #5 of 6 Old 08-24-2011, 11:17 AM
oldtime_ironman
Plasti-gauge is your friend. See here:
post #6 of 6 Old 08-24-2011, 02:07 PM
Jims-87YJ
1987 YJ Wrangler
Not an expert by any means but this may be simple, there was another thread here i think were the bolts on the Vibration dampener were to long and hitting the timing cover? A quick easy check Good Luck, hope its not to involved.
1987 YJ, 258, Weber 32/36, HEI, Custom Sound bar, Hardtop/Sun-rider/bikini tops, 2" Lift, 1/2" Boomerangs, 1" Body & MM Lift. 32x11.5x15 Copper STT's on Black Rock 950 Lobos w/4" backspacing, Still need Front Bumper and Seats.
My build thread:
Jims-87YJ is offline
