I'm about to give up on the g/d thing!!! - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > I'm about to give up on the g/d thing!!!
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 02-26-2010, 06:11 PM   #16
dodger889
Here is the problem that I'm reading. You are dumping gas pass the rings. I would do a compression check or leak down on the cylinders. If you have low compression the engine will never run right.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote Quick reply to this message
Unread 02-26-2010, 06:38 PM   #17
HayWrangler
I feel your pain bud,
the guy I bought my jeep from was somewhat dishonest but such is life.....for around here I still got a fair deal.
Almost three months later I'm on the road even drove to work in it the other day after spending a couple of weeks riding around the neighborhood scared
Keep at it its worth it even with all the bloody knuckles and $100 bills out the window the jeeps alot of fun this is my first.
I will say I have great respect for those that daily drive these and dont have another vehicle.
Maybe the throttle body is bad, what about checking the timing? Keep us updated.
HayWrangler is offline   Reply With Quote Quick reply to this message
Unread 02-26-2010, 06:55 PM   #18
monkeyhouse
Got my DD in July, finally on the road in November. Converted to Weber Carburetor, replaced, water pump, radiator, hoses, nutter bypass, Teamrush, now I have a broken shock mount and bad slave cylinder, but I'd never give up on it, if you are passionate, you will work hard and make sure you do it right the first time, eventually it will run like a kitty and you will have the time of your life, hang in there.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline   Reply With Quote Quick reply to this message
Unread 02-27-2010, 02:08 PM   #19
rain-gler
Ok here's my findings:
The injector's o-rings are bad. I saw 2 of them and the bottom one was cut. My assumption is that when I turn the key the fuel was priming and leaking past the o-ring into the intake. (this would explain the flooding)
I might have a reprieve. More money for beer instead of buying an injector. Plus I was able to knock on the starter to get it going again.
Does anyone know off hand what size o-ring I need or should I just ask at the auto parts store?
If that works, looks like I have to change the oil again. The oil pan is completely full of gas.
Well, maybe that will clean out some sludge.
rain-gler is offline   Reply With Quote Quick reply to this message
Unread 02-27-2010, 03:07 PM   #20
Mark05059
you can buy just the orings for the injectors.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread 02-27-2010, 03:10 PM   #21
SDGBASSE
If you haven't been able to start the engine, next time you try put some oil mixed with Lucas or Mistery Oil in the cylinders thru the spark plugs holes, especially if the engine hasn't been started in a while by the previous owner, I went thru almost the same thing as you and it just didn't want to start since the compression was too low because the piston rings were seized in the piston. As for the o'rings, that's what I found on RockAuto.com :GB REMANUFACTURING Part # 8005 {FUEL INJECTOR SEAL KIT; INJECTOR SEAL KIT}, should work out just fine then.
[QUOTE=ZeroGravity;10681914]I didn't click the link because it says "power probe" in the url.[/QUOTE]
SDGBASSE is offline   Reply With Quote Quick reply to this message
Unread 02-27-2010, 03:47 PM   #22
rain-gler
thanks guys.
Im running out to Azone right after watching the Las Vegas race.
Unread 02-27-2010, 03:55 PM   #23
TDHofstetter
What's wrong wi' you, boy? A JEEP's a-waitin'! Get them clodhoppers on & git out thar!
TDHofstetter is offline   Reply With Quote Quick reply to this message
Unread 02-27-2010, 07:26 PM   #24
Mark05059
spoken like a true Vamonah
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Unread 02-27-2010, 08:33 PM   #25
rain-gler
UPDATE:
I slapped the o-rings on and she's sealed up tight. No more leaks or squirting.
Bad news: That starter is toast. Its smoking and gurgling.
I gotta slap in a starter and change out the gas...I mean oil. (there's more gas in the oil pan than oil.)
Other than that, everything looks okie dokie (knock on wood)
Unread 02-27-2010, 09:15 PM   #26
TDHofstetter
Excellent! Well, pretty GOOD, anyway!
Yer nearly nearly there.
Unread 02-27-2010, 09:37 PM   #27
rain-gler
yeah, once I get it running I can move on to the "easy" fun stuff like
-swapping in a front axle
-replacing the rear wheel brake cylinder
-new radiator
Unread 02-27-2010, 09:52 PM   #28
idaholtby
One thing you can rule out is the fuel pressure regulator. When the diaphragm ruptures, pressurized fuel is sucked up the vacuum line and floods the intake manifold. Check the vacuum line on your fuel pressure regulator and see if it is fuel soaked. I don't see how bad injector o-rings can cause flooding of the crankcase with gas. They seal the injector to the fuel rail on on end and to the intake on the other. If they leak,it is to atmosphere (external), they can not cause a leak across the injector. I'm not saying that they don't need replaced, just that this not likely your flooding problem. When replacing these o-rings, lube them with Vaseline, then gently rock the injector to seat it. Do not twist or rotate, as this type of motion can damage the o-ring.
idaholtby is offline   Reply With Quote Quick reply to this message
Unread 02-28-2010, 12:08 AM   #29
MJMPC
When you changed from TBI toMPI you did use the MPI computer didnt you?
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
http://www.cityprofile.com/
MJMPC is offline   Reply With Quote Quick reply to this message
Unread 02-28-2010, 08:47 PM   #30
rain-gler
@idaholtby
The broken o ring was allowing fuel to dump past the injector into the intake when the pump primed and while cranking. After I replaced it, I had no problems whatsoever. She starts right up and sprays pretty good.
@MJMPC
I swapped a 91+ MPI engine to my 89 TBI set up. I changed in my old TBI intake manifold and kept my TBI computer, wiring and set up.
The only other things I had to do was change the alternator bracket, and the crankshaft pulley from serpentine to v-belt. And I found out the hard way that I had to keep my original flywheel (for the crankshaft sensor).
It starts right up but after a while, it starts running a bit rough. Pressure looks pretty fair.
Im going to open it up to see what it has before I do anything else to it. It might be running rich. I intend to test the O2 sensor and check the vacuum lines.
