ignition system trouble on 2.5 L - JeepForum.com
post #1 of 3 Old 05-02-2007, 10:47 PM Thread Starter
cjist1
cjist1's Avatar
Im getting this strange electrical misfire while under acceleration, usually only at RPM's higher than 2500. Its not really a misfire like when you have bad wires that are shorting out. Its more severe, like all cylinders are not firing for a split second. I have replaced plugs, wires, cap and rotor. Coil is only 2 years old. Its like a cough or sputter. I also replaced the entire engine wiring harness because the original one was hacked up and shorting out. Im starting to suspect the computer is starting to go bad. Most of the time the speedometer does not work either. It is either on for an entire ignition cycle or off, it never stops or starts in the middle of an ignition cycle. Are these symptoms of a failing ECU?
92 YJ 2.5L 5 spd.
75.6hp/100.0 ft,lbs.
cjist1 is offline
post #2 of 3 Old 05-03-2007, 02:05 AM
YJ_
YJ_'s Avatar
your problems (other than the speedo) sound like a faulty ECU. When mine was on its last leg I would "sputter" while being under throttle. It usually happened on the highway past 40 mph. I don't really know any way to test the computer ( I bought one over the forums, replaced the new (to me) one with my stock one and it's been running fine ever since. This was on a 94 S.
"if ya can't duct it **** it"
[] IIIII []
YJ_ is offline
post #3 of 3 Old 05-03-2007, 08:47 PM Thread Starter
cjist1
cjist1's Avatar
Yeah that sorta sounds like the symptoms Im having. Maybe I will try to find an ECU. Thanks.
92 YJ 2.5L 5 spd.
cjist1 is offline
Ignition system upgrades freeskier93 TJ Wrangler Technical Forum 9 01-01-2010 12:31 PM
Ignition system upgrades?? Tjosh97 TJ Wrangler Technical Forum 11 10-19-2009 10:01 AM
Ignition switch trouble? mforbes YJ Wrangler Technical Forum 2 07-24-2009 02:04 PM
Trouble finding ignition wire Benny2Times TJ Wrangler Technical Forum 5 07-19-2008 08:15 PM
New ignition system for 4.2 - what kind? crankyman YJ Wrangler Technical Forum 7 05-22-2006 06:55 PM
