ignition switch install pics? - JeepForum.com
post #1 of 5 Old 05-17-2010, 10:25 AM Thread Starter
247Cat
Hey all... new on the forum and new to jeeps..
I just got a 92 wrangler 4.0 5spd and i need some help.
Previous owner said ignition switch was bad, well was not there at all.
i picked up a new one. I can rod and harness but there are no switch or bolts or anything near there.
anyone have pics of what it should look like. maybe an exploded view or something?
Its super hard to see up there, do i need to drop the steering column?
repair manual does not have a diagram.
247Cat is offline
post #2 of 5 Old 05-17-2010, 10:37 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Will this help?
Tilt Column Fix - Dale's Jeep Junk
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 5 Old 05-17-2010, 11:50 AM Thread Starter
247Cat
It will help a ton.. thanks.
this is the pic i needed.
247Cat is offline
post #4 of 5 Old 05-17-2010, 04:38 PM
Tompatt
1987 YJ Wrangler
sorry for being even more of a noob. but are you talking about were you insert the key?
Thomas
-1987 YJ
Tompatt is offline
post #5 of 5 Old 05-17-2010, 04:45 PM
Fernando
Fernando's Avatar
1987 YJ Wrangler
The ignition lock cylinder is where you insert the key, to get to that one you need to take the steering column apart, the ignition switch is an electrical part located on top of the steering column and you can get to it without removing the steering column, with slim hands and patience.
Hope this helps
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
1999 TJ Ignition Switch Replacement-Install stu602 TJ Wrangler Technical Forum 10 03-23-2015 12:50 AM
TJ bezel removal and switch install *Pics* Kip03TJ TJ Wrangler Technical Forum 5 06-29-2010 05:13 PM
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-28-2009 12:02 AM
Quick question on headlight switch install! *PICS* frontmounted TJ Wrangler Technical Forum 6 06-07-2006 04:24 PM
