Ignition switch HELP!!! - JeepForum.com
post #1 of 4 Old 09-24-2005, 04:56 PM Thread Starter
Josephrk24
I just bought this used Yj and i need to change the ignition switch key thing... But i dont know how to get the old one out... Do i need to take the column apart? Is there a special tool that i need to do it?.... Can i even do it my self?......Can someone help me.........
Josephrk24 is offline
post #2 of 4 Old 09-24-2005, 07:05 PM
Jeepfan Jeff
Jeepfan Jeff's Avatar
Walk in the Park, You can do it. You will need a steering wheel puller and a lock plate removal tool. When you get those off you'll have to loosen the turn signal switch and pull to the side then there should be a flat spring steel clip that will pull straight up then the key cylinder will pull out. just pay attention to how the little parts come out and you wont have any problems.
90 YJ, 4.2, 5sp
3" rrrrrough ccccountry lift
custom f/r bumpers w/swingaway tire carrier
weber 551-38
nutered and juiced
Ramsey Pat. 9500
(5)33x12.50x15 wildcats
eagle alloys 058
Missouri Offraod Outfitters over the top axle truss
M.O.O. rock bruiser diff cover
bushwacker cut-out flairs
shrockworks rock sliders
sorry no pics of the Schrocks & Bushies yet(but soon)
personal garb.
Jeepfan Jeff is offline
post #3 of 4 Old 09-24-2005, 07:11 PM
fastasu
Its pretty simple. Only special tool that you need is a puller to make getting the steering wheel off easier. take horn cap off and start your way in. If I can remember all you need is a phillips, 15 mm (I think) socket and wrench,and the puller. Go slow and you'll do fine.
Matt
fastasu is offline
post #4 of 4 Old 09-24-2005, 07:59 PM Thread Starter
Josephrk24
Ok thank's i'll start tomorrow...
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-27-2009 11:02 PM
ignition switch help! please sloppyrodpumper YJ Wrangler Technical Forum 4 10-15-2007 11:03 PM
Ignition Switch speedfreak331 YJ Wrangler Technical Forum 1 12-02-2006 02:05 AM
ignition switch sandman'sjeep YJ Wrangler Technical Forum 2 02-17-2006 07:50 AM
Ignition Switch??? paintguy YJ Wrangler Technical Forum 5 08-09-2005 12:06 AM
