Ignition switch connector YJ 88 - JeepForum.com
post #1 of 1 Old 08-25-2005, 07:53 AM Thread Starter
pearlwing
Is it the connector on top of the steering column? I have 2 connectors on top and 2 on the bottom which I believe are the wipers/washer/turn connectors. The reason I'm trying to find these wires is because I've swapped a 350 in the jeep and I'm trying to connect the starter. Diagrams dont tell location, at least not the one I have...
thanks
pearlwing is offline
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-28-2009 12:02 AM
Broken connector to ignition coil ddrongowski YJ Wrangler Technical Forum 1 07-07-2009 03:50 PM
HELP! Oil Pressure Switch (elbow connector) pacopaco YJ Wrangler Technical Forum 3 12-08-2008 11:40 PM
Ignition Off Draw Connector Grateful Jeep YJ Wrangler Technical Forum 3 07-09-2006 11:30 AM
Foglamp switch connector TJJP77 TJ Wrangler Technical Forum 8 01-31-2006 09:55 AM
