Ignition Switch Actuator Rod - JeepForum.com
post #1 of 5 Old 08-04-2011, 07:41 PM Thread Starter
Mistry
Hello, I'm a newbie to the forum and this is my last hope, my jeep wrangler 1988 ignition switch actuator rod is not moving and need help on how to fix it. I have replaced the key locking cylinder and ignition switch module and the movement is still smooth when I turn the key locking cylinder and no start. Reaching up under the dash I can move the rod by hand only. Can not figure out how to get the lower shroud off to get to the rod and what to do next. It has a tilt steering wheel column. Can anyone help me? Thank You
Mistry is offline
post #2 of 5 Old 08-04-2011, 08:15 PM
Old4X
1990 CJ7
The rod has likely popped out of place either at the top or down on the switch itself.
Does the engine start and run if you move the rod by hand?
If so, the rod has popped out of the little gear in the top of the steering column.
You will have to pull the steering wheel and start taking stuff apart till you see the little cam shaped toothed gear. The rod snaps into this gear, the gear is turned by the housing holding the key lock.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 5 Old 09-05-2011, 02:37 AM Thread Starter
Mistry
After months of dead ends and no real help from the forum, I have figured it out. If you need help with your ignition problems call me at 925-360-3450 and I will talk you through it. I will not be on the forum. Be well
Mistry is offline
post #4 of 5 Old 09-05-2011, 09:18 AM
nembudonna
What the hell does this guy mean? If you don't like the forum, then just go away.
nembudonna is offline
post #5 of 5 Old 09-05-2011, 10:56 AM
timatoe
timatoe's Avatar
He means he made one post and got a realistic response, didn't take the advice, and is now pissed. I don't know seems kinda childish, but then there seems to be a lot of that going on around here the last couple of days.
timatoe is offline
Ignition Switch Actuator Pin Repair jdgrip TJ Wrangler Technical Forum 2 04-13-2012 10:28 PM
Ignition Actuator out...Push Button Start? sstump TJ Wrangler Technical Forum 1 06-12-2011 08:59 PM
Ignition actuator pin roughknight69 TJ Wrangler Technical Forum 1 12-08-2010 05:18 PM
T-case vacuum switch actuator? TrynPas YJ Wrangler Technical Forum 14 04-18-2010 11:35 PM
Vacuum Actuator Switch 4wd HanksRide YJ Wrangler Technical Forum 1 02-02-2010 07:19 PM
