ignition switch - JeepForum.com
post #1 of 3 Old 02-14-2006, 10:13 AM Thread Starter
sandman'sjeep
ignition switch
does anyone know how many wires (and color codes) come out of this switch... wire diagram that I have from an alarm company (black widow alarms) shows only 3 wires coming out of the ignition. It shows one wire going to the battery, one is the ignition and the last one to the starter... not giving up on this... thanks
sandman'sjeep is offline
post #2 of 3 Old 02-14-2006, 12:31 PM
MaineYJ
i can email you a couple of pictures that are labeled if you can pm me your email address.
87 YJ 258, 2" BL, 33"BFGs, NV3550, np231, mc2100, HEI, CJ Aluminum Valve Cover, and NO computer
MaineYJ is offline
post #3 of 3 Old 02-17-2006, 08:50 AM Thread Starter
sandman'sjeep
FYI for anyone wants to know where your ignition switch harness is... found mine located on top of the steering wheel inside... noticed it was being fastened down by some kind of metal brace... and that the wire colors werent the same as some had posted (all together there are 8 wires)... does anyone know how to remove this harness without breaking it?
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-28-2009 12:02 AM
ignition switch help! please sloppyrodpumper YJ Wrangler Technical Forum 4 10-16-2007 12:03 AM
Ignition Switch speedfreak331 YJ Wrangler Technical Forum 1 12-02-2006 03:05 AM
ignition cut off switch TJ_Firefighter TJ Wrangler Technical Forum 7 08-14-2006 10:54 AM
Ignition Switch??? paintguy YJ Wrangler Technical Forum 5 08-09-2005 01:06 AM
