Ignition Problems - JeepForum.com
post #1 of 10 Old 02-27-2007, 06:49 PM Thread Starter
03WrnglerSahara
03WrnglerSahara's Avatar
Ignition Problems
I own a 1994 YJ Manual Shift...Ok so I installed 2 new KC Offroad lights today and when I went to start my jeep it wouldnt start checked my ignition coil it was not sparking, so I replaced it and still it will not start now its too dark to get any work done and I would like some advice on what to try next.
Also i've never had this problem before but my clutch (fairly new less than a year) doesnt seem to work, i can shift freely among gears with out having to press down the clutch whats the deal with that? This happened after the installation of the auxiliary lights btw.
03WrnglerSahara is offline
post #2 of 10 Old 02-27-2007, 08:00 PM
bobbert350
bobbert350's Avatar
im guessing your motor cranks right??...also are you sure that you didnt disconnect one of the wires that would give you a spark...i did something like that when i put my msd in one of the wires that ran to the coil got disconnected or clipped from the previous owner it was the purple wire and it gave no spark...thats prob not gonna help but worth a shot.
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #3 of 10 Old 02-27-2007, 11:24 PM
Bob_R
did you use a relay or did you wire hot to the switch?
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL TREAD LIGHTLY
Bob_R is offline
post #4 of 10 Old 02-28-2007, 12:08 AM Thread Starter
03WrnglerSahara
The wiring that came with the lights has a built in relay. In any case I have a wire (yellow) connected to the battery and another wire (white) connected to the right headlight per the directions...everything has been grounded correctly and all the electricals work, headlights new aux lights radio etc, it does crank just wont turn over, tomorrow im going to check all my fuses and wires make sure everything is connected and then check my spark plugs. any other ideas?
post #5 of 10 Old 02-28-2007, 06:51 AM
sprngrider
When any car is off, you can shift gears without the clutch. Since you installed the lights, have you tried to charge your battery? It sounds like maybe you drained it.
sprngrider is offline
post #6 of 10 Old 02-28-2007, 08:46 AM Thread Starter
03WrnglerSahara
just replaced the battery and still nothing it cranks but wont turn over
post #7 of 10 Old 02-28-2007, 09:08 PM Thread Starter
03WrnglerSahara
just wanted to say i found the problem...it seems when i was moving around stuff to find a space to put my wires for the lights thru i knocked around the PCM which in turn prevented a current from getting to my ignition coil but anyway i re-tighted the bolt on the PCM and shes rumblin like thunder again i'll post picks of the lights and the re painted dash tomorrow after i take pics
post #8 of 10 Old 11-24-2011, 04:33 PM
redgolds
folks, I undersstand this post is a few years old
But, what doespcm stand for and do I have one on my 1991 wrangler? 2.5L engine
redgolds is offline
post #9 of 10 Old 11-24-2011, 04:43 PM
stevedude19
i think its the same as ecu/ecm - the computer for the jeep
95 YJ Rio Grande 2.5L 4cyl 30" BFG ATs 4 inch rc lift 4.0L TB Cold air intake (302 swap in progress)
2010 JK 6 speed
stevedude19 is offline
post #10 of 10 Old 11-24-2011, 05:21 PM
redgolds
ok thanks
redgolds is offline
ignition problems exavious YJ Wrangler Technical Forum 11 06-13-2011 12:14 PM
yj ignition problems. help 89yjwheeler YJ Wrangler Technical Forum 9 01-18-2010 03:19 PM
Ignition problems Level_1 TJ Wrangler Technical Forum 1 03-07-2009 06:48 PM
Ignition Problems Jeepguy8794 YJ Wrangler Technical Forum 1 07-30-2007 01:21 PM
Ignition Problems ryko212 YJ Wrangler Technical Forum 3 09-06-2004 06:54 AM
