Quantcast Ignition problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Ignition problem
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 09-18-2009, 09:50 PM   #1
landon123
Ignition problem
hey,
I have i 1989 jeep yj that i recently bought. it was running fine when i got it but now i am having some problems. the first sign of the problem was when i was cruising the engine would shut off momentarily then come back on in a bitt. this adventively kept on getting worse to the point the jeep won't even start. now i am not getting any ignition at all. i replace the wires, plug, cap, rotor, ignition coil and the pick up for the distributor. (which are all from a 1985 ford f150 inline 6 4.9 L for some reason). Does any buddy know were to go from there?
thanks
landon
landon123 is offline   Reply With Quote
Old 09-18-2009, 10:09 PM   #2
Dutra177
check the carburetor, it might me gummed up with some residue. Take it off and clean it up.
Dutra177 is offline   Reply With Quote
Old 09-18-2009, 10:13 PM   #3
yjmoose
Might have a bad ignition box. On the 4.2 6 cylinder it is located on the driver's side fender under the coolant reserve. (i think) I don't know how to test and see if its bad as I replaced my entire ignition system with a gm HEI. I do seem to remember that the ignition box is prone to failure. I am sure someone who actually KNOWS will follow up.
yjmoose is offline   Reply With Quote
Old 09-18-2009, 10:27 PM   #4
timatoe
Jello Puddin'
timatoe's Avatar
The Ignition Control Module is located under the washer fluid bottle on the driver side inner fender. That's where I'd start.
Originally Posted by jbolty View Post
... never underestimate the idiocy of Nancy Pelosi...
timatoe is offline   Reply With Quote
Old 09-19-2009, 05:19 PM   #5
landon123
ok I will took for the ICU, the carb just got a electronic choke on it and that was messing up to, it was keeping it open once and a while but i am not to sure about that it not getting spark
Old 09-22-2009, 07:44 PM   #6
landon123
ok so i put a new ICU on it and still don't have ignition? any one know what else it can be?
Old 09-22-2009, 11:31 PM   #7
timatoe
Jello Puddin'
timatoe's Avatar
How do your battery cables look?
Old 09-24-2009, 02:52 PM   #8
landon123
there fine everything gets power great, but no spark when it is turning over
Old 09-25-2009, 07:20 AM   #9
Dutra177
take your spark plug cable out and stick a screwdriver in the boot and see if a spark arcs when you crank it over. If it does then you know everything before the spark plugs is ok and the spark plugs are bad. If it doesn't arc that means your not getting any power to the cables or before them. Keep troble shooting and work your way back to find the problem.
Tri-City Jeep Club Member #68
2006 Jeep TJ Rubicon
We're gonna make Jeepers out of you!
Glock Forum
