Ignition issues-Firing early/late? - Page 2 - JeepForum.com
post #16 of 21 Old 02-28-2014, 07:26 AM
Que89YJ
PM sent call me
Que89YJ is offline
post #17 of 21 Old 02-28-2014, 08:58 AM Thread Starter
XJ93
I'll call you when I get back home to the Jeep. Took the wifes car to work today so I could drop it off at the shop for an alignment.
XJ93 is offline
post #18 of 21 Old 03-08-2014, 12:32 PM Thread Starter
XJ93
Sorry I didn't get a chance to call you Que. I did get my ECM in though, and it seems that for now all the weird issues I have been having have cleared up. I even have a cel illumination! Code 15 is No vehicle speed signal. Speedo hasn't worked in over a year, new sensor and still not working. Now I can actually get down to that.
XJ93 is offline
post #19 of 21 Old 03-08-2014, 01:30 PM
Que89YJ
Awesome.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #20 of 21 Old 03-08-2014, 01:48 PM Thread Starter
XJ93
The parts guy at the dealership looked through the vents in my old ecm and said "When did it get all cracked inside?" I replied that it had looked that way since I got it. "You got screwed." Ouch. From now on I think I will stick to new or dealer parts for my electronics. That just hurt.
Also worth noting that the old ecm never popped a code for the speed sensor. Now I know that it might either be an alignment issue or I got the wiring screwed up when I replaced the sensor. Now that it's sunny out, back under the Jeep I go.
XJ93 is offline
post #21 of 21 Old 03-08-2014, 04:42 PM
Mark05059
just an easy check. remove the adapted from the transfer case turn the key to on and spin the gear with a drill. if the speedo works its an alignment problem. if it doesnt its a wiring problem
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
