ignition issue help! - JeepForum.com
post #1 of 5 Old 06-03-2006, 01:36 PM Thread Starter
jeep795
so i got a 92 wrangler with a 6 cylinder. i got a car jumper hooked up to the battery and when i go to start it the thing clicks like a fiend. when i let off the key but leave it on, i hear a humming coming from the steering column and a buzzing coming from a square, either fuse or sensor, not sure which. are those what could be causing her not turning over?
jeep795 is offline
post #2 of 5 Old 06-03-2006, 01:47 PM
Nuthin
Curses! Foiled again!!
Nuthin's Avatar
Have you checked your battery cables to make sure the connections are clean, uncorroded and all the cables are intact? That sort of clicking generally indicates either a dead battery or bad cables/connections. I would imagine the buzzing and humming are likely seatbelt/door alarms since I doubt you're belted in when you do this and it seems likely the door is also open.
--Please put my quote in your signature. Love, 'Shux
--I'd rather have that than tapwater you can light on fire. - Lone Jeeper
--You're doing it wrong. - Cause --I don't care. At least I'm doing it. - AKABOB
"The minute you hear ‘freedom’ and ‘democracy’, watch out…because in a truly free nation, no one has to tell you you’re free.” Jacque Fresco
Wardrobe by Levi, makeup by Chance, hairstyle by Wrangler
Nuthin is offline
post #3 of 5 Old 06-03-2006, 03:13 PM Thread Starter
jeep795
well that's the thing i don't even have seatbelts in the jeep yet and no doors. but anyway i through the battery on the charger for a few hours and the jeep started right up. i replaced the starter this morning anyway. but i'm getting this whining/ whistling noise from the engine, when i hit the gas it sounds like someone blowing a whistle from soft to loud.
jeep795 is offline
post #4 of 5 Old 06-03-2006, 03:51 PM
92 Green YJ
92 Green YJ's Avatar
hmmm, could be the starter relay is going bad.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #5 of 5 Old 06-03-2006, 05:54 PM Thread Starter
jeep795
any ideas on the whisteling?
jeep795 is offline
ignition/electrical issue. romo1000 YJ Wrangler Technical Forum 11 09-24-2009 08:19 AM
Is this an ignition module issue? racerx8413 YJ Wrangler Technical Forum 5 09-15-2009 07:49 PM
Wet Ignition Issue wsroman TJ Wrangler Technical Forum 0 08-01-2009 09:59 PM
Ignition Issue or bad key?? chico166 JK Wrangler Technical Forum 17 12-06-2007 05:56 PM
HELP GUYS: ignition issue standnstillfast YJ Wrangler Technical Forum 9 01-07-2006 12:56 PM
