Ignition issue - JeepForum.com
post #1 of 2 Old 06-13-2011, 01:08 AM Thread Starter
cinneman
1930 MK Compass
Ignition issue
I haves 92 yj and recently the only way it will start is if I move the tilt steering up and down while turning the key to the start position. If I turn the key by itself it does absolutely nothing. I did notice a white module on top of the column under the dash and it looks like the ignition has a rod that goes into it when turned could this be the culprit?
You wouldn't understand.....
cinneman is offline
post #2 of 2 Old 06-13-2011, 09:34 AM Thread Starter
cinneman
1930 MK Compass
Or could it be something inside the column?
cinneman is offline
