Ignition I think? - JeepForum.com
post #1 of 4 Old 03-28-2002, 06:10 PM Thread Starter
dcbeer
Ignition I think?
Hope someone can help? My 88 4.2 started running like S#*T shortly after I bought it started with the vac. lines (lot of them). Did not find any leaks or improve the situation. Would still die at every stop. Cleaned out the idel tubes worked for a weak. Well did the nutter bypass life was good again except was running rich. Kind of expected that. ordered a weber carb, put it on and it ran great except for the 8 mpg. In my planning when I did the bypass I ran new wire from the controll to the dist. and put terminals so it could be easily reversed, which I did today. so after putting all the hoses and and what not back on I went to change the wires over and found that the purple wire had pulled apart at the dist. It ran this way, had good power but I am suspecting this was the cause of my poor mpg. Does any have any ideas before I bypass again as it is running like before I pulled everything off the first time. Also what does the purple wire control.
1988 yj, computer bypass, webber carb and the ever famous BA10/5 transmission (if you have one you know it or will find out).
dcbeer is offline
post #2 of 4 Old 03-29-2002, 02:05 PM Thread Starter
dcbeer
Well did the bypass again today made sure all wires that were spliced were secure>> This time when I set the timming I set it at 8 deg. (BTDC). Before I was not sure if the timing was set at 900 RPM or 1600 that the info under the hood states. Well anyway at 900 RPM and 8 deg. (BTDC) it ran good, so I assume it is ok now. Still trying to find out what the violet wire from the dist. to the computer does. Also will have to wait and see if my mpg gets any better than 8.
Not that it matters all that much but was wondering what kind of milage I can expect out of a 4.2L
dcbeer is offline
post #3 of 4 Old 03-29-2002, 03:08 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
After driving 200 miles on a fillup, I'm seriously looking for a gas station. That averages to around 15-16 mpg.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #4 of 4 Old 03-29-2002, 04:09 PM Thread Starter
dcbeer
I can live with that. Sure would beat 8 I was getting.
dcbeer is offline
ignition randomly turns on after jeep is turned off and ignition locked karthac YJ Wrangler Technical Forum 3 01-12-2010 09:35 PM
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-28-2009 12:02 AM
Questions about ignition wires and other ignition stuff Fernando YJ Wrangler Technical Forum 10 08-11-2009 06:33 PM
Pre Ignition??? dodge_4by4 TJ Wrangler Technical Forum 13 12-22-2008 01:18 PM
MSD Ignition, anyone put one on a 258? johnrezz YJ Wrangler Technical Forum 1 10-20-2008 08:31 AM
