This ignition is driving me nutz!!!!
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
I have a 94 yj 2.5 4cyl. 5 speed. When i try to start it, i have no spark... If i keep trying (5 or 6 times) it will start up and then run fine. If i shut it off and restart it right away it starts right up, if i let it set five or six minutes it has no spark again.
I tried replacing the ignition switch, thinking it might have a bad contact in it. It started right up, then i drove the 45 minutes home from work, shut it off and let it sit for 5 minutes it cranks but has no spark.. Any ideas? I am totally lost here......
94 2.5 4 popper 5 spd. All stock with 31x10.50's |
#2 |
Does Anyone Have A Used Ecu For A 94 2.5 5 Spd?
#3 |
Check all the connections to the coil an/or replace it.
89' YJ Larado 4.0L,AX15 01' Grand Cherokee 4.0L Check my Gallery for pics. My Rebuild Thread Take a minute and fill out your profile, Please |
#4 |
im having the same problem with my 95 4cyl and someone told me that it is the camshaft sensor?
#5 |
I had a problem with starting that was intermittant like this. My check engine light would not light up but when I waited with the ignition on for several minutes it would eventually fire up.
I was told it was several different sensors and relays but they did not fix it. I finally broke down and replaced the ECU. Problem solved. I found the best deal at rockauto.com. Good luck. |
#6 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
