Ignition control module - JeepForum.com
post #1 of 13 Old 07-29-2010, 10:59 PM Thread Starter
jeep108
Think my icm is going south, starts, idles & runs for a little while, then stutters and dies. Won't start again till it cools down. I searched the forum and found several post about using an icm from an early 80's ford. My question is about the plugs, do I need to cut the plug off the old icm and splice it to the new one? Any thing else I should know? Thanks!
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
post #2 of 13 Old 07-30-2010, 05:45 AM
Que89YJ
Look at the team rush and nuttering it. Get rid of the ICM and the vacuum stuff for the pollution controls all together.
Que89YJ is offline
post #3 of 13 Old 07-30-2010, 07:05 AM Thread Starter
jeep108
Sorry, thought i had updated my profile,(Its been fixed), Its been nuttered and rushed. I did the team rush mod about 2 weeks before the trouble began, I kind of wondered if maybe all the new ignition parts put too much strain on the old icm but I don't really know how all that works. I have gotten rid of the vac stuff except the dist advance and egr.
How do you go about cutting out the icm without going to an hei system?
jeep108 is offline
post #4 of 13 Old 07-30-2010, 07:10 AM
Old4X
1990 CJ7
You have to keep the ICM, it is the ECM tht you can toss.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 13 Old 07-30-2010, 07:22 AM
jbolty
jbolty's Avatar
Or, go with an HEI and toss everything else.
jbolty is offline
post #6 of 13 Old 07-30-2010, 07:59 AM
Que89YJ
That is exactly it. Go to the HEI.
Que89YJ is offline
post #7 of 13 Old 07-30-2010, 02:00 PM
greyarea
I parsonally would not go hei as you have a good system as is you just need a quality module (Motorcraft) you can use one for an 86 ford bronco with a 351 in it swap the connectors it will work perfect. I have one that I was about to put on ebay for $20 but it is a parts store brand one and run for about 5000 miles if you want it.
90 YJ Magnum 5.2 v8 , 1'' BL, 1'' booms, 4" Procomp, 35/12.50-15 MTR/kevlar Ford 8.8 4.10 lsd Aussie and TJ shafts up front.
KI4UTU
greyarea is offline
post #8 of 13 Old 07-30-2010, 07:03 PM
Old4X
1990 CJ7
The ground for your entire ignition system is under the cap on your distributor. Have you checked and tightened it? (it is the gold screw holding the wiring harness to the pickup in place).
Next, add a dedicated ground wire from the distributor to a known good ground to the battery.
These Jeeps are 20 years old or so, grounds do corrode and work loose.
Old4X is offline
post #9 of 13 Old 07-31-2010, 12:28 AM Thread Starter
jeep108
Thanks guys, yeah for now I would just assume stick with the system I've got since I just did the team rush & upgraded the coil.
Greyarea, I appreciate the offer but I think I've got a motorcraft here local that I can get pretty cheap.
Old4x, Thanks for the tip about the ground, never even thought about it but I'll add it as well
Thanks again
jeep108 is offline
post #10 of 13 Old 08-05-2010, 08:57 PM Thread Starter
jeep108
Put an old motorcraft icm on, the difference is amazing
jeep108 is offline
post #11 of 13 Old 08-05-2010, 10:09 PM
JPRatYJ
i just got a brand new one with a lift time warrenty for 80 bucks now she starts like a dream EVERY TIME and i know im covered if it ever goes out again
/l ,[_____], 1990 YJ 4.2 Weber 34
l---L -[]lllllll[]- 4in Rustys, 3in body, 1.25 Shackles
()_) ()_)--o-)_) 33 Kumo's M/T and smittybilt tube fenders -----Johnny Rat-----
JPRatYJ is offline
post #12 of 13 Old 08-09-2010, 03:56 PM Thread Starter
jeep108
Yeah, new probably is the way to go I just wanted to know it'd make a difference before I spent any $$$$ & the old one was free, did you buy one made for a jeep or go with the one for the early 80's ford?
jeep108 is offline
post #13 of 13 Old 08-09-2010, 05:21 PM
JPRatYJ
i went with one that was made for the jeep it was only 80 bucks with a lift time replacement....
JPRatYJ is offline
How Can I Test Ignition Control Module (ICM)??? inniett YJ Wrangler Technical Forum 16 12-23-2016 12:18 AM
HELP! How to tell if 4.2 Ignition control module is bad? yjcrawlr YJ Wrangler Technical Forum 8 01-03-2009 02:46 PM
Where is my ignition control module? parakleets YJ Wrangler Technical Forum 15 06-27-2007 10:17 PM
ignition control module rolledthatho YJ Wrangler Technical Forum 14 03-30-2006 11:48 PM
where is my ignition control module rdarmstrong YJ Wrangler Technical Forum 5 12-23-2002 10:12 PM
