Ignition Coil Pigtail Connector - JeepForum.com
post #1 of 8 Old 10-01-2012, 11:47 AM Thread Starter
TA-YJ
The retaining clip on the pigtail that connects to my ignition coil has been broken for a while. Recently the connector has started walking itself out of the coil as I have been driving causing the Jeep to die and me to get out and plug it back in. Does anyone know where I can get a replacement pigtail for that connector? Thanks.
1992 YJ 2.5L
Engine Mods:4.0L TB, Ford Design III 19lb Injectors, Firepower Ignition System, Ford TBird Electric Fan, Pacesetter Header, Magnaflow Cat, Dynomax Super Turbo Exhaust
Suspension Mods:BDS 2" Lift, M.O.R.E. 5/8" HD Shackles, 1" Brown Dog MML
Other:LED Tails and Herculined
TA-YJ is offline
post #2 of 8 Old 10-01-2012, 12:15 PM Thread Starter
TA-YJ
Called the local jeep dealership and they told me their computer doesnt go back that far for electrical connectors.
1992 YJ 2.5L
TA-YJ is offline
post #3 of 8 Old 10-01-2012, 05:00 PM
Cobra Jeep
Local junkyard is your best and fastest way to get one. Otherwise, I have one I can send you. If you dont mind waiting a few days to get it, PM me your address and I will drop it in the mail.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #4 of 8 Old 10-01-2012, 05:14 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
If it is the plastic piece that goes on top of the coil you can get them at napa for under ten bucks.
Michaelgoesrawr is offline
post #5 of 8 Old 10-02-2012, 02:47 PM
Darold
NAPA has them, very in-expensive.
Darold is offline
post #6 of 8 Old 11-11-2013, 12:34 PM
fivenine
Hey does anyone know where I can find these now? I searched on the Napa website - nothing.
Thanks!
fivenine is offline
post #7 of 8 Old 11-11-2013, 05:00 PM
Mark05059
http://www.napaonline.com/Catalog/Ca...238_0334589929
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 8 Old 11-13-2013, 03:00 PM
fivenine
Is this piece still needed for the Kolak Ignition Kit?
fivenine is offline
Busted TPS Pigtail Connector - Help!!! Dimitri F TJ Wrangler Technical Forum 2 04-19-2012 06:07 PM
Ignition Coil connector sequel YJ Wrangler Technical Forum 1 07-31-2011 11:37 AM
ignition coil connector redalloy YJ Wrangler Technical Forum 3 06-23-2011 03:23 PM
Broken connector to ignition coil ddrongowski YJ Wrangler Technical Forum 1 07-07-2009 02:50 PM
Ignition switch connector YJ 88 pearlwing YJ Wrangler Technical Forum 0 08-25-2005 06:53 AM
