If you had 3k to spend.... - JeepForum.com
post #1 of 31 Old 09-08-2011, 08:42 PM Thread Starter
1993sahara
Okay i have a 1993 sahara, no lift with 31's. not sure how soon but i may be getting 3k to invest into my jeep to make it more "up to date".. just looking for ideas as to what to do?? the suspension has been narrowed down to two options either old man emu 2.5 or bds 2in. i just wanna fit 32's. also figured on a slip yoke eliminater and a cv shaft. just looking for other things that would make if more comfortable to take on longer trips and not have to worry if some 18 year old part is gonna break on me. maybe some ideas to upgrade steering parts or bushings, axles, any idea is welcome.. thanks guys
93 Sahara 4.0, ax15, BDS 2 inch springs, MORE greasable 5/8hd shackles, Ford 8.8 rear, AA sye, Quigley cv shaft, 32" wrangler mtr with Kevlar
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
1993sahara is offline
post #2 of 31 Old 09-08-2011, 08:51 PM
jeepinvader
I would suggest a winch, but I'm guessing it won't be taken off road very much. Correct me if I'm wrong.
Free Chuck!
jeepinvader is offline
post #3 of 31 Old 09-08-2011, 08:55 PM
moonshinefuel
Personally I'd be leaning towards a 3.5 inch lift if you are going with an sye
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #4 of 31 Old 09-08-2011, 08:58 PM Thread Starter
1993sahara
Yes the jeep will be taken off road. I've had for over three years now and offroading/mudding used to be an every sunday event.
I have thought of that kit as well but it's going to be one of this two company's
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #5 of 31 Old 09-08-2011, 09:05 PM
CSquare93
Definitely go higher if you want to get the full benefit from the SYE and CV driveshaft. In your description, this jeep sounds more like a daily driver? If so, maybe re-gear to get better gas mileage at highway speeds. I know it shouldn't break with just 32's but you could consider swapping the rear axle out for an explorer 8.8. It'll get you disk brakes all the way around and more reliability.
CSquare93 is offline
post #6 of 31 Old 09-08-2011, 09:10 PM
ejeeperguy
1982 CJ7
Don't go that crazy with the 3000 bucks. You can cut the wheel wells open and put new flares in to give you some needed clearance.The other thing is redo the swaybar bushings, tie rod ends,ball joints. I used lift shackles in mine and I'm running 33's .You might even want to regear the axles with going with the bigger tires.
ejeeperguy is offline
post #7 of 31 Old 09-08-2011, 09:11 PM
Drix
I would do an Axle swap also.
95' YJ 4" lift 33"x12.5r15's D30/8.8 locked with 4:88's
USMC Jeep Club #6
"Why in hell can't the Army do it if the Marines can. They are the same kind of men; why can't they be like Marines."
Gen. John J. "Black Jack" Pershing, USA; 12 February 1918
Drix is offline
post #8 of 31 Old 09-08-2011, 09:14 PM
moonshinefuel
I will throw in a vote for keep your stock springs and go soa on 32's. Not sure that 3k would cover it...but, I don't think you'd regret doing it if its done right.
Bow Hunting
post #9 of 31 Old 09-08-2011, 09:20 PM Thread Starter
1993sahara
The jeep is my DD. Soa with stock leafs isn't gonna happen cus my leafs are shot, fronts have negative arch right now. I thought about the 8.8 swap just would also have to rehear the front or find one already done. Maybe have alittle more then 3k to spend as well.
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #10 of 31 Old 09-08-2011, 09:29 PM
Bearsma
How bout,,,,,,, another jeep? I just picked up my 97 Tj for 3k. Can NEVER have too many jeeps ya' know. :0).
~Bear. USMC
GREEN JEEP CLUB #587
Bearsma is offline
post #11 of 31 Old 09-08-2011, 09:39 PM
Kodiak17
Go with BDS. The difference between OME and BDS is too small. I have my 2" lift waiting in the garage for my TJ. Have fun with that 3k!
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #12 of 31 Old 09-08-2011, 09:43 PM
jeepnbrett
Front locker.... You will go places you didn't think were possible.
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
post #13 of 31 Old 09-08-2011, 09:43 PM
Missouribound
3K to spend?? Get another YJ and use it as your project toy. You mentioned long trips for this one....leave it alone and buy a beast you can play with.
Missouribound is offline
post #14 of 31 Old 09-08-2011, 09:54 PM
jhumphrey
Honestly, you're eating through that 3k pretty quick. BDS will run you around $600 if you piece it together.
$2400 left. 32" tires will run you around another $600 (depends on brand and I presume you'll get 5 and I also figure your rims will work...)
1800 left. YSE - $300. (though I dont think youll need one with just a 2" lift).
1500 left. An 8.8 rear (built to spec, ready to put in): ~$900 delivered.
~600 left to spend. New R&P for the front: $150 (presuming you do the install yourself)
~$450 left. $450 doesnt go a long way...just enough for a winch, but you need a winch bumper / plate.... so... yeah...
jhumphrey is offline
post #15 of 31 Old 09-08-2011, 09:54 PM
panaceabeachbum
3-4" LIFT , 30 spline front axles and front locker
panaceabeachbum is offline
$ to spend :) Welke TJ Wrangler Technical Forum 8 08-14-2009 11:24 AM
Help me spend $250 -Zona- JK Wrangler Technical Forum 12 05-01-2009 11:05 PM
best way to spend $50 01amberfirewv TJ Wrangler Technical Forum 10 12-19-2006 11:44 AM
$350 to spend drew76924 TJ Wrangler Technical Forum 11 06-18-2005 09:03 AM
$75 to spend on TJ... CoriolisSTORM TJ Wrangler Technical Forum 17 12-30-2004 07:42 AM
