If I am running a MC2100 do I need a fuel Regulator? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > If I am running a MC2100 do I need a fuel Regulator?
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 07-13-2009, 11:40 PM   #1
Matsuno
I found a holley regulator and a Jegs gauge through some of the other threads.
Holley reg: http://www.jegs.com/i/Holley/510/12-804/10002/-1
Gauge: http://www.jegs.com/i/JEGS/555/41040/10002/-1
What is the point of running these? I currently have the MC2150 with electric choke hooked up but she is bogging down and almost stalling under load. I have to push the clutch in to keep her running. and it is sputtering when I accel. I am taking it in to a carb specialist on Wensday, so he can check to make sure it is running right but should I install the regulator and gauge right after?
I know a few people are running these and any help/ advice is greatly heard. I thought about pulling the MC out and switching to a weber but don't know which one to go with. Besides a lot of you are running MC with nothing but great things to say about them.
Josh
'90 Wrangler YJ Islander, 4.2L I6, MC2150, EFI (Team Rush Upgrade), 2" BL, 4" Skyjacker Lift, 35" Mickey Thompson Baja Claws
Matsuno is offline   Reply With Quote Quick reply to this message
Unread 07-14-2009, 05:51 PM   #2
emahan01
bump also wondering this as i am swaping to motorcraft carb ?
2.5 susp,1.25 body,aussie front 33x12.5 mud country, rokmen front,trail gear rear bumper, winch, straps
emahan01 is offline   Reply With Quote Quick reply to this message
Unread 07-14-2009, 06:20 PM   #3
ScottsYJ
ScottsYJ's Avatar
I do not have a fuel regulator on mine and have no issues. I know that the webers require them. Searching the forum for info when I did my swap, I did not come across anyone using a fuel regulator with a MC2100.
Proud YJ owner since 10.25.2008.
Teamrush mod, MC2100 carb, Nuttered, BDS 2" Lift kit, BrandonYJ Shackles 1/2", AA SYE, Tom Woods DS,
31" Goodyear Duratracs, Magnaflow CAT, Flowmaster Delta 40 Muffler, Monstalined, MSD 6A Ignition
ScottsYJ is offline   Reply With Quote Quick reply to this message
Unread 07-14-2009, 06:23 PM   #4
4.7stroker
If you have kept the fuel return line then NO you do not need a regulator.
If you have disabled the fuel return then YES you need a regulator.
Dwayne
4.7stroker is offline   Reply With Quote Quick reply to this message
Unread 07-14-2009, 09:55 PM   #5
scott5star
scott5star's Avatar
not to steal ur thread but i just installed a weber 32/36 and did not install reg properly so i pulled it off. it still runs fine. am i at risk of messing something up over time. its never stalled or had rough idle or anything since the conversion
scott5star is offline   Reply With Quote Quick reply to this message
Unread 07-15-2009, 06:48 AM   #6
vadslram
Not sure on your setup but the fuel filter has a bypass/regulator built into it and it works just fine for my 2100/4.2 combo.
vadslram is offline   Reply With Quote Quick reply to this message
Unread 07-15-2009, 07:12 AM   #7
Mike1084
1979 CJ7
I run a MC2150, (fuel return line), with no regulator. No problems. Here is a good link/w pics for a 2100/2150 .pdf carb rebuild doc. http://www.therangerstation.com/tech..._2150_carb.pdf
Fuel pressure regulators all have the same purpose - to maintain a constant fuel pressure above the intake manifold pressure. They are used to regulate and flow of fuel pumped by fuel pumps and maintain a constant pressure into the carb. Excess fuel is restricted and returned to the tank, (via the return line).
Mike1084 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2009, 03:50 PM   #8
Matsuno
I kinda found the answer to this. But Tazman and 4.7 are correct you do not need to run one with the MC2100/ or the 2150. As long as you maintain the fuel return line from the filter. If you go a one to one with the inline filter then you will need a fuel pressure regulator around (3-3.5psi).
Thanks guys.
Josh
Unread 12-26-2014, 10:06 AM   #9
2k2wranglerx
reviving a really old thread.
i'm having overfueling issues (i think). is there any benefit to not running a return line?
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline   Reply With Quote Quick reply to this message
Unread 12-26-2014, 10:37 AM   #10
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Nope. The return line is supposed to come off the top of a level filter with the carb line in the center. This way on a hot shutdown, any vapours produced get blown off the top of the filter back to the tank preventing vapour lock.
The filter has a metered hole in the return to hold 5-7 psi at the carb.
I see dirty air filters on the gas tank vents causing issues or blocked vent lines when folks swap carbs mistakenly thinking that charcoal canister is a power eating emissions part. It isn't, it actually helps gas mileage slightly by leaning the high speed mix a little and has an air filter on it's bottom..
To check the vent system out, just run with the gas cap cracked open.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
