Idling problem wen coming to a stop - JeepForum.com
post #1 of 5 Old 05-14-2010, 07:14 AM Thread Starter
parkerm26
Okay so i just finished my frame welding repairs and got my SYE and CV shaft in (ITS SO SMOOTH!) but now i'm having a problem. Wen i am coming to a stop or a turn and the engine is slowing it down, or i down shift, the jeep will hit extremely low RPM's but after a few seconds, come back up to normal, or stall. if i am accelerating faster or just constant and press the clutch its fine. i can kind of draw a diagram
pressing clutch while: downshift/decelerating---------constant speed----------accelerating faster
RPM's with clutch in: stall-100/100-300------------------300-400-------------------700(normal)
i used to down shift all the time. this has never happened.
DETAILS: JB SS SYE installed. speedometer is not hooked up yet as i need to splice the wires. The T case was removed from the jeep and done on a bench. The jeep sat for about a month total. i took the positive terminal off to weld the frame. the engine was hanging on straps for a while that were under the tranny and holding it up with the frame. new fluids- enigine got new 10-30, tranny got 10-30, trans case got dex 3 equivalent
Please ask any questions if you have an idea of why this is happening or any input
93YJ 350-465-205, D60 and 14 Bolt, 40's http://www.jeepforum.com/forum/f22/yj-rustoration-1327569/
parkerm26 is offline
post #2 of 5 Old 05-14-2010, 07:52 AM
TSEJEEPERS
Your Jeep needs the speedo hooked up to help control the idle.
Once you hook the speedo up your problem will go away.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 5 Old 05-14-2010, 08:02 AM
WRMJeep
Also make sure your vaccum lines for the front axle are connected to the T-Case. If not you will have a vaccum leak which could cause an issue.
WRMJeep is offline
post #4 of 5 Old 05-14-2010, 01:08 PM Thread Starter
parkerm26
yeah that 4 way vacuum line that goes into the top of the t case looked like it wasn't getting a good seal but i plugged it on as tight as i could. my jeep specialist mechanic said it might be something to do with the vacuum lines but i thought i hadn't screwed anything up there. thanks TSEJEEPERS i'll get the diagram and splice them in. i already spend enough money i'm not buying the adapter unit unless its less than 10 bucks and i can find it at my local auto parts store which i'm fairly certain i can't haha
post #5 of 5 Old 05-17-2010, 04:45 PM Thread Starter
parkerm26
that did it. Thanks man!
Heater on high, engine idling. What is the air temp coming out of vents? yellojeeper TJ Wrangler Technical Forum 12 11-29-2008 06:18 PM
YJ Cuts off when coming to a stop 89 JeepYJ YJ Wrangler Technical Forum 9 07-17-2008 02:46 PM
Im idling at 1500 at stop lights and when i turn it on, HELP 94YJEEPER YJ Wrangler Technical Forum 0 03-25-2008 03:36 PM
Idling fine until coming to a complete stop 70sElvis YJ Wrangler Technical Forum 5 12-29-2007 07:54 PM
Rough idling, dying while idling...tranny problem? MissLarramendy TJ Wrangler Technical Forum 7 07-25-2004 03:20 PM
