Idling issues - JeepForum.com
post #1 of 4 Old 10-07-2004, 10:32 AM Thread Starter
jsandmel
Idling issues
I have 1989 YJ 6-cylindar. At cold start the engine idles at 1500 or so, depending on where I set the idle, but once the engine warms up, the idle drops so low that the engine often stalls at stops. Anyone know what this could be? I just rebuilt the carburetor and the engine should be in pretty good shape.
Thanks in advance
JS
jsandmel is offline
post #2 of 4 Old 10-07-2004, 10:36 AM
pushead
I hope you didnt waste your money rebuilding a Carter. Even after a rebuild it is still a pain in the butt. Dump it and buy a new one. That will solve your issue.
Its not a jeep if it dont have 4wd.
pushead is offline
post #3 of 4 Old 10-07-2004, 10:37 AM
oct7brian
oct7brian's Avatar
Mine does the same thing sometimes but only when its cold... like 40 or below outside. No idea
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline
post #4 of 4 Old 10-07-2004, 03:47 PM
kg6mti
1987 YJ Wrangler
I have a 1987 YJ with the I6 and the Carter carb. My Jeep does exactly what yours is doing. I finally gave up on the carb. My mechanic said mine is just too old and wore out. He got it to somewhat idle again but said the problem will return.
I ordered the Mopar MPI kit this week and it should arrive today.
Good luck! But the advice they guy have is good. Either buy a new carb or get one of the two injection kits (Mopar or Howell)
kg6mti is offline
Idling issues after dead battery Iamjr TJ Wrangler Technical Forum 2 01-25-2010 10:20 AM
idling low mikeym41240 TJ Wrangler Technical Forum 13 07-31-2009 04:37 PM
4.0 idling issues WVjeep94 YJ Wrangler Technical Forum 13 01-23-2009 02:09 PM
Weber Idling Issues hguffman YJ Wrangler Technical Forum 2 01-20-2005 12:03 PM
Rough idling, dying while idling...tranny problem? MissLarramendy TJ Wrangler Technical Forum 7 07-25-2004 03:20 PM
