Idler pully? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Idler pully?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 08-21-2006, 02:00 PM   #1
89_Sahara
2011 JK Wrangler
Idler pully?
My idler pully locked up and my jeep ate the belt that goes between my fan and alt. I'm having trouble finding a new pully. I tried all the local parts stores and even called checked the dealership. I checked quadratec and 4wdhardware and I still couldn't find what I needed. Where can I get a new pully?
89_Sahara is offline   Reply With Quote
Unread 08-21-2006, 04:07 PM   #2
89_Sahara
2011 JK Wrangler
Any Ideas?
Unread 08-21-2006, 05:02 PM   #3
olbigen
I just replaced both pulleys on my 91 4.0. I bought them from my Chrysler dealer, he had them in stock.They may be different from your 89 though.
olbigen is offline   Reply With Quote
Unread 08-21-2006, 05:09 PM   #4
rick95
Autozone.com has got an idler pulley for an 89 wrangler for $20. It also says it should be a normal stock item at any local auto zone, not sure if you checked there. But if not, you can buy it right off line.
green 95 4-banger
4" RE lift, 33X12.5 Kumho venture M/T, Cragar soft 8's, PORC SYE, wood's shaft
rick95 is offline   Reply With Quote
Unread 08-21-2006, 05:25 PM   #5
Yule16MET
ive been looking for a vbelt pully for my power steering belt for weeks and the only ones that have it are steelerships and they want 96 bucks for one pully.
and a 4.0 has a serpintine system and the 4.2 has a v-belt. Sometimes
I dream of the jeep, drive the chevy and roush pays for it all
1990 YJ lerado,Soa,2.5R.E.springs,8.8,4.88'sPSC trail cage&rocker nockers w/sliderbars,home made bumpers, 35"boggers,sye, tomwoodsds, revolvers, red & yellow optima, bushwackers,corbeua ss seats,mc2100,juicebox, 3core rad., b&mshifter and highlift,5point harnesses,wheel spacers,9000lb mile marker,ssdash kit,no sway bar, no trackbar, walmart lights,clinometer, XJ passenger shaft, axle tube seals, M.O.R.E track bar
And a Monster Yellow CJ5
40x17's 12"lift full cage
Blackjeepclub #16
Armyjeepclub #16-#1
yellowjeepclub #BIG16
Yule16MET is offline   Reply With Quote
Unread 08-21-2006, 07:01 PM   #6
EMT
not sure on yours but on mine u just pull a snap ring off and can change the bearing for bout 5 bucks.
88yj hardtop ,4.2 i6, 3.5 BDS lift,1"daystar bl,165 amp alt. ,homemade1"mml with 33" 12.50 baja claws ,mickey thompson classic locks .aussie locker in front and a warn 8000lb winch.2 kc daylighters on the windsheild,2 55w driving lights on the bumper.pioneer cd and speakers,sound bar and amp.ford taurus fan and tfi ignition upgrade.mc2150 upgrade,discoed.nutter bypass,8.8 rear end ,grant steering wheel.
EMT is offline   Reply With Quote
Unread 08-21-2006, 08:37 PM   #7
89_Sahara
2011 JK Wrangler
Where can I get a replacment bearing?
Unread 08-21-2006, 08:54 PM   #8
EMT
any parts store,my small town mechanic even had it in stock and he hardly ever has anything in stock.he said it was a very commonly used bearing.
