idler pulley - JeepForum.com
post #1 of 7 Old 01-14-2014, 04:59 PM Thread Starter
kampoyj
idler pulley
Hello all
95 YJ 2.5L Left hand drive no A/C
I know my idler pulley on the left hand side to the thermostat housing is gone and I received a replacement today
Unfortunately I did not check parts catalogue first and the part number part I received is replacing 53002905 from CROWN
Looking at parts cat today it seems the 95 had another part number for one pulley which I am not sure which one it is and if indeed the above would do just fine still? they look exactly the same in size and shape hence me thinking that would do
pic attached
any idea if this will be an issue?
'95 YJ, 2.5L,140000Km
SPICE SOFT TOP, CEPEK SHOCKS,1-1/4 Conferr HD Shackles,31X10.5 BFG MT/S,AMERICAN RACING OUTLAW IIs 15X8 3.75 BACKSPACING,JKS QUICK DISCOS
kampoyj is offline
post #2 of 7 Old 01-14-2014, 05:01 PM Thread Starter
kampoyj
sorry I should also say I see a part number 4792 112 but not sure if this part number is for the pulley in the pic above or not. I think this is the same as the one I received i.e. 53002905 but can anyone confirm or let me know if that would work ok still?
kampoyj is offline
post #3 of 7 Old 01-14-2014, 05:03 PM
kahanabob
same size and shape i would go for it.......
kahanabob is offline
post #4 of 7 Old 01-14-2014, 05:39 PM
jojojeep1
for $5 I just bought a set of bearings put one in the back and one in the front , done works great
jojojeep1 is offline
post #5 of 7 Old 01-15-2014, 02:53 AM Thread Starter
kampoyj
Hello thx for replying
What tupe of bearing should i buy? Do you know codes or part number?
kampoyj is offline
post #6 of 7 Old 01-15-2014, 09:43 AM
Que89YJ
Que89YJ is online now
post #7 of 7 Old 01-16-2014, 06:42 PM
jojojeep1
no I just went to sears , and I took the pully with me after taken out the old bearings , and matched up the bearings with the hole in the center of the pully, I found bearings that fit right in that center hole.
