which idle speed screw on weber to turn? - JeepForum.com
post #1 of 3 Old 05-04-2011, 09:29 AM Thread Starter
masonz
just installed a new weber 32/34 on my 89. Im trying to set the idle to the specs that ive found on the forums. My question is, there are two idle set screws on the carb, which one is the 2 turns out when adjusting?
masonz is offline
post #2 of 3 Old 05-04-2011, 11:50 AM
jstang
The one on the rear of the carb, the one on pass side is your high idle.
jstang is offline
post #3 of 3 Old 05-04-2011, 03:44 PM
mcmud
1983 CJ8
Without a more specific identification of the carb it is rather hard to pinpoint the locations of the screws.
Generally speaking the screw that controls the throttle plate position at curb idle is most often referred to as the idle speed screw. Its tip will make contact onto the linkage.
Then there is at least one idle mix screw, threaded into the body of the carb and it controls the fuel flow needed to support a steady curb idle.
And then the fast idle speed screw is most often located behind the choke assembly.
mcmud is offline
Quick idle speed question - Weber Carb - Speed Screw 2.5 turns in, but 0 vacuum unlucky YJ Wrangler Technical Forum 1 04-22-2011 05:30 PM
For those with AC and Weber carbs, quick fix for idle speed Fernando YJ Wrangler Technical Forum 5 03-30-2011 05:48 PM
Idle Speed too low w/Weber 551 el scorcho YJ Wrangler Technical Forum 6 03-10-2011 12:27 PM
Weber side idle screw fell out help please lidlitalian YJ Wrangler Technical Forum 2 03-12-2010 11:16 AM
weber 32/36 idle speed woes odie YJ Wrangler Technical Forum 0 01-24-2002 09:30 PM
