Idle setting problem - JeepForum.com
post #1 of 5 Old 11-05-2011, 12:19 PM Thread Starter
bluedaffy
My idle screw doesn't seem to want to consistently return all the way to the idle bar (the stop for the idle screw) on a 4.2L YJ. Does anybody know of a reason as to why it wont return all the way? does it need greasing? new springs?
*More information*
This happened when I went to turn down the idle, it had been idling at around 1200 rpms and wanted something more around the 800 rpm range. When I screwed down the idle screw it still returns to the 1200 rpm range because the screw isn't pulled all the way to touch the stop plate.
Thanks!
bluedaffy
bluedaffy is offline
post #2 of 5 Old 11-05-2011, 03:34 PM
kahanabob
can you push on it to make it touch the stop plate? if so then maybe a new spring or adjust it for more tension.....if not then something else is interfearing with it.....
kahanabob is offline
post #3 of 5 Old 11-05-2011, 04:26 PM
jsawduste
2006 YJ Wrangler
Sorry but your posts just don`t make sense.
You state you have a 91 YJ but in your profile you call it a 4.2.
The two engines 4.0 and 4.2 are two different animals .....Thus the engine controls are two totally different between the years.
The 4.0 (standard in 91 and up) is an OBD 1 fuel injected.
The 4.2 (standard 87-90) is a Renix (Renault and Bendix) controlled system with a Carter carburetor.
What do you have ? If you don`t know at least post a picture and we can figure it out.
jsawduste is offline
post #4 of 5 Old 11-05-2011, 05:44 PM Thread Starter
bluedaffy
The engine is a 4.2 but in a 91 tub
post #5 of 5 Old 11-05-2011, 07:00 PM
jsawduste
2006 YJ Wrangler
OK, then is it a RENIX or OBD1 controlled ?
Or is it a stand alone carb/distributor set up ?
If the latter then what carb and dist ?
Sorry to ask so many questions but the JF wrecking crew can`t give you good advice if we don`t know the game.
Reply here and fill out your profile with the information for future reference.
idle , idle issue , spring
91 YJ Idle Problem YJ_Rick YJ Wrangler Technical Forum 3 03-18-2009 09:37 AM
4.2 Idle Problem mideerhunter YJ Wrangler Technical Forum 7 08-30-2008 11:27 PM
High idle , speedo moving while setting still TJ on the Rocks TJ Wrangler Technical Forum 1 04-24-2007 07:49 AM
Problem setting my toe-in leonw TJ Wrangler Technical Forum 1 10-02-2006 12:09 PM
FINALLY! fixed idle problem and stalling problem Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-28-2006 08:50 PM
