Idle problems.... - JeepForum.com
post #1 of 7 Old 04-01-2013, 10:24 PM Thread Starter
Bigphil
Idle problems....
Hello, I am a owner of a 90 jeep wrangle....it has the 4.2 straight 6 cylinder...I am having issues with at idle.....I have replaced plugs, wires. Dist. Cap rotary button. And installed a new webber carb....I have checked compression all cylinders have 100 to 110..so Itake it no burnt valves....any help would be greatly appreciated.....new to the jeep scene but you guys rock..thanks
Bigphil is offline
post #2 of 7 Old 04-02-2013, 07:42 AM
Chris
Guy with jeep
Chris's Avatar
Have you messed with the timing?
Chris is offline
post #3 of 7 Old 04-02-2013, 09:05 AM
hdfxrs91
1987 YJ Wrangler
Check for vacuum leaks?
hdfxrs91 is offline
post #4 of 7 Old 04-02-2013, 11:19 AM
JCashen
Was the nutter bypass done previously? If not when you changed to a weber your computer still controls timing. Look up nutter bypass and make sure your timing is no longer controlled by the computer.
"Drippy"
90 YJ 5.2 Magnum MS3x, D60/GM 10.5", ORI struts, 4 link
JCashen is offline
post #5 of 7 Old 04-02-2013, 01:36 PM
Old4X
1990 CJ7
Take the computer completely out and leave it out, useless once you changed the carb.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #6 of 7 Old 04-02-2013, 08:34 PM Thread Starter
Bigphil
Haven't messed with the timing......did think it had a computer, why would it....thanks fellas
Bigphil is offline
post #7 of 7 Old 04-02-2013, 09:14 PM
Old4X
1990 CJ7
Computer is behind and under the glove box
Old4X is offline
