Idle problem HELP - JeepForum.com
post #1 of 15 Old 12-14-2013, 01:25 AM Thread Starter
ClayJohnson
Idle problem HELP
So bassicly my jeep won't idle unless I rev it non stop, once I stop revving it my jeep will turn off comepletly, I thought it was the carborator like it had to be clean really well but I took it into a jeep dealership and they said I need a new motor and carb, I told my friend they said I need a new motor and he said that cant be right that I need a whole new motor and he thinks its the carb! Someone try to help me please!!! To be honest I don't know a lot about jeep motors and everything like that haha.
ClayJohnson is offline
post #2 of 15 Old 12-14-2013, 07:24 AM
Maverick1998
Might be a bad battery
my 98 GC won't idle if the battery is bad
Maverick1998 is offline
post #3 of 15 Old 12-14-2013, 07:32 AM
WDNewman
You don't need a new motor. You need to educate yourself to keep from being scammed.
WDNewman is offline
post #4 of 15 Old 12-14-2013, 07:53 AM
halmc
LOL, a little blast of spelling might not hurt either.
halmc is offline
post #5 of 15 Old 12-14-2013, 08:56 AM
Chrisnvegas
Chrisnvegas's Avatar
This is what's probably wrong.
http://www.jeeptech.com/engine/carter.html
Takes minimal tools and 15 to 20 minutes in your driveway.
When you hear mechanics talking crazy, always get a second opinion.
Ban computer updates and autoplay video! Boycott music without real instruments and singers using autotune.
Chrisnvegas is offline
post #6 of 15 Old 12-14-2013, 01:01 PM
Old4X
1990 CJ7
Yes, a posibility, along with about 50 others.
As I mentioned in the OP's twin thread, he needs to DIAGNOSE the problem before throwing fixes at it.
If this doesn't fix it, then what? New carb? Valve job?,new CTO valve? new cat converter?, New distributor? New computer? New ICM? New SolVac? etc, etc, etc.
All the above and much more can do this
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 15 Old 12-14-2013, 01:30 PM
jeepguy85
1987 YJ Wrangler
Have you checked for any vacuum leaks? Also, check for leaks around the carb. I would also check your timing. I am assuming you have the stock Carter carb, which is a complete turd. Most who own a Jeep with the Carter have swapped it out for more reliable carbs.
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
post #8 of 15 Old 12-14-2013, 02:11 PM
Old4X
1990 CJ7
He can not swap carbs in Ca. He can put a certified fuel injection system on or another OEM carb, those are his options
ETA, my Carter is fine, not a "complete turd"
Old4X is offline
post #9 of 15 Old 12-14-2013, 02:14 PM
Chrisnvegas
I picked that because it' pretty common and the fix is easy and free.
I shake my head because almost every thread starts with
"It's still doing it. So far I replaced the coil, belts, hoses, plugs, wires, cap, rotor, tie rod adjustment nozzle ect."
post #10 of 15 Old 12-14-2013, 02:24 PM
jeepguy85
1987 YJ Wrangler
He can not swap carbs in Ca. He can put a certified fuel injection system on or another OEM carb, those are his options ETA, my Carter is fine, not a "complete turd"
You are one of the lucky ones. I personally have never seen one run correctly. I guess CA law also means no nutter bypass?
post #11 of 15 Old 12-14-2013, 02:42 PM
Chrisnvegas
Carters did not leave the factory running poorly. Many of these carbs have been performing well for 20 years.
If they are not performing well after service, the rebuilder is defective, not the carb.
post #12 of 15 Old 12-14-2013, 02:51 PM
jeepguy85
1987 YJ Wrangler
Carters did not leave the factory running poorly. Many of these carbs have been performing well for 20 years. If they are not performing well after service, the rebuilder is defective, not the carb.
I understand that. I agree with you. I personally have never seen one running well. Let's not turn this into a carb debate. Let's help the op solve his issue.
post #13 of 15 Old 12-14-2013, 06:40 PM
Old4X
1990 CJ7
Easy and free if the owner can do it.
I had plugged idle air bleeds, but could still make it idle so it was drivable. Took two tuning sessions, but it did OK till I could find the cause. It was a poor quality idle, but wouldn't stall at a stop. The idle tube mod returned it to a sewing machine type idle, even at 300 rpms (was curious how low it would run).
For a 4.2 that has been worked on and still will not idle without stalling , more serious problems or a combo of several sound like whats going on to me.
Do not forget, when you take a Jeep to a big shop, you are paying to work on a $30,000 piece of equipment. The parts and labor are priced in line with the new ones.
Old4X is offline
post #14 of 15 Old 01-05-2014, 11:30 PM
mcnallysport
Here is a good resource to learn how the Carter Carburetor works, which helped me solved my idle problem.
http://u225.torque.net/cars/SL6/docs/BBD_Manuals.pdf
mcnallysport is offline
post #15 of 15 Old 01-06-2014, 12:28 PM
Peety
Here's a question, what was the fault that the dealership identified necessitating an engine replacement ? Most stores will not give an engine the kiss of death with out a very good reason. What did they say was wrong with it.
-Poor compression
-Excessive leak-down
-Improper valve operation (wiped out cam)
Peety is offline
idle problems
