Idle increase when braking - JeepForum.com
post #1 of 4 Old 07-10-2013, 05:38 PM Thread Starter
Reno72
It sounds like I have a vacuum leak where my pedal pushes into the booster. I hear a vacuum inside the cab and my idle speed increases. I have not noticed a change in my braking while moving or sitting, the pedal holds it's place not going lower while pushed in. Does this sound like time for a new booster or can you just change the plunger?
Reno72 is offline
post #2 of 4 Old 07-10-2013, 06:54 PM
superj
When the jeep is not running and you step on the brake, it holds solidly? Usually a rise in idle speed when pushing the brake is a leak in the booster diaphram . Google is your friend, amigo
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 4 Old 07-10-2013, 07:36 PM Thread Starter
Reno72
Actually I did google and did a search here, it seems opinions differ from that's normal, to you need a new booster. I figure it's the booster as I don't remember hearing the vacuum in the cab. Only thing throwing me off is my brakes act normal while driving, sitting at a light, and on a hill. I was hoping to do the bigger brake booster once a switch to the 8.8 and disc's so I can bleed and rebuild the front and back all at once. I guess I'll have to do the booster now.
Reno72 is offline
post #4 of 4 Old 07-10-2013, 08:39 PM
superj
Mine leaks and acts normal. I will fix mine sometime also. Same description as yours
superj is offline
