idle adjustment - JeepForum.com
post #1 of 4 Old 04-08-2010, 09:41 PM Thread Starter
newyj
idle adjustment
how would you adjust the idle, mine seems a little low?
wave back dammit, don't leave me hangin!
yes, I wave at night too
newyj is offline
post #2 of 4 Old 04-08-2010, 10:17 PM
dodger889
You can not adjust the idle. Now how low is idling?
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #3 of 4 Old 04-08-2010, 10:38 PM
djsmith1174
You can make some adjustment to the idle by adjusting the small torx screw on the throttle body linkage (at least you can on my 4.0L TB). I did this when I swapped the TB because it was idling a few hundred RPM too high. It's not real easy to get to if I recall correctly though.
djsmith1174 is offline
post #4 of 4 Old 04-09-2010, 01:46 AM Thread Starter
newyj
dips to 500-600 sometimes
newyj is offline
Idle Adjustment/Sol-Vac Problem? OPlo YJ Wrangler Technical Forum 11 11-02-2015 10:38 PM
Idle adjustment Inzano YJ Wrangler Technical Forum 0 03-14-2009 10:08 PM
Idle adjustment tj7695 YJ Wrangler Technical Forum 3 02-15-2009 09:04 AM
Idle adjustment... how? exc911ence TJ Wrangler Technical Forum 8 07-25-2006 11:41 PM
Idle adjustment crownlvr YJ Wrangler Technical Forum 0 07-28-2002 04:12 PM
