identify'n my engine - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > identify'n my engine
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!
Unread 04-12-2010, 01:54 PM   #1
SkullTripper
1987 YJ Wrangler
With this picture can you tell me what my engine is from?
[B][U]Its a Jeep thing....[/U][/B]
[COLOR="Lime"][B]My 1987 Jeep Wrangler Build..[/B][/COLOR]
[url]http://www.jeepforum.com/forum/f22/z-o-r-v-87yj-build-slow-978747/[/url]
SkullTripper is offline   Reply With Quote Quick reply to this message
Unread 04-12-2010, 02:09 PM   #2
SloppyJoseph
How about a picture of the engine?
SloppyJoseph is offline   Reply With Quote Quick reply to this message
Unread 04-12-2010, 02:59 PM   #3
timatoe
timatoe's Avatar
Are you certain that a full 4.0 swap was done and not just the head and MPI? From what I'm getting (if I'm deciphering right) that number is a 4.2 built on Feb. 6th of 1987.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 04-12-2010, 03:34 PM   #4
YJMonster
im getting the same as timatoe
2000 xj 4.5 Rubicon Express extreme duty(sold)
1988 yj 2.5 RC lift, 1/2 boom shackles- My baby
YJMonster is offline   Reply With Quote Quick reply to this message
Unread 04-12-2010, 05:35 PM   #5
SkullTripper
1987 YJ Wrangler
Henestly you know more about my engine then me so your prob right.. because I have 4.2 flexplate and no hesco parts or anything like that but I do not have a carb... heres some pictures maybe they will help (sorry my camera broke had to use the video camera...
Unread 04-12-2010, 08:24 PM   #6
Burnerman
Something is giving a CPS signal if that engine runs. Look behind the drivers side of the intake manifold there should be wires running to the CPS bolted to the top of the bellhousing. It's just below the firewall and hard to see.
89' YJ Larado 4.0L,AX15
05' Grand Cherokee Limited, 2"OME lift and a Hemi.
Burnerman is offline   Reply With Quote Quick reply to this message
