Identify this lift.... - Page 2 - JeepForum.com
post #16 of 18 Old 02-12-2013, 05:22 AM Thread Starter
Gohot
Yep, the track bar was removed a couple months ago, right after I initially wrote this thread. Boy what a difference, I felt a much better suspension movement. The rear still has to come out, but the PO welded the through bolt head to the axle tower mount about a quarter of the way around. Of course he fried the bushing doing so and it clanks on acceleration and deceleration. Initially I had got a cutoff blade for my side grinder to cut the weld so that I could remove the bolt, but grinding at 35,000 rpm threw a shower of sparks. Dang, I was afraid of blowing the whole thing up so I stopped immediately. I went to tractor supply and got a drill mounted grinding stone to fit my small drill. The low rpm of it ought not to throw sparks, and ought to cut the weld out in a couple minutes time hopefully.
Thanks for IDing the springs guys. Let me ask you then..... with 2.5 Rubicon Express springs and the shackles shown in the picture, what do you think my lift system comes out to? I'm thinking the shackles are lifting maybe 1 1/2" to maybe 2" , giving a total of 4" ?? Does that sound right?
With this information i could try to compute the loss of caster and decide on what degree of wedges and only buy once instead of back and forth with them and the distributor. I did get a gauge from Harbor Freight that ought to show soon, for my exact measurements.
Other than the wandering feel, it's good to full throttle in 5th of about 70-75ish without wobble or bounce or anything, it's quite smooth. Remember, it sets on 31x10.50's.
Gohot is offline
post #17 of 18 Old 02-12-2013, 10:22 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The two inches added by the shackles only results in one inch of lift. All things being equal, you're adding two inches on one side of the spring while the other stays fixed and the axle (being in the center of these two points) will move exactly one half the distance that you lift one side.
One inch shackle lift. Stock is 4".
Luck Favours The Prepared
Anticanman is offline
post #18 of 18 Old 02-12-2013, 11:12 AM
bgredjeep
1987 YJ Wrangler
The wandering can be the result of the drag link angle. When the TREs wear the tie-rod will rotate when you turn left and right causing a dead spot when you transition. A drop pitman arm or a tie-rod flip might flatted it out enough to fix that and any bump steer you feel as well. You could drop to a 5" shackle (1/2" lift) and it will give some of your caster back. Have you had to alignment checked to make sure it is correct?
Based on the shackle lift only you should have lost ~2.5 of caster with the 1" lift shackles. So a shim that same amount to get it back, or drop to a 1/2" shackle and you will get ~1/2 of that back. If you go with shims, make sure you get steel shims (not aluminum) and make sure your center pins are long enough to go through into the hole in the spring perch. I don't think that will be an issue with such a small shim.
bgredjeep is offline
Can anyone identify this lift? Lerawk JK Wrangler Technical Forum 9 06-17-2011 06:29 PM
Help me identify the lift(s) on my TJ Danacus TJ Wrangler Technical Forum 5 04-11-2011 04:40 PM
please help me identify this lift... 02jeepwrangler TJ Wrangler Technical Forum 11 06-14-2010 06:30 PM
Identify lift tims03TJ TJ Wrangler Technical Forum 12 12-24-2009 02:58 PM
Identify This Lift .. SuMeRiaN TJ Wrangler Technical Forum 13 06-28-2007 09:17 PM
