Identify this lift.... - JeepForum.com
post #1 of 18 Old 08-02-2012, 05:01 AM Thread Starter
Gohot
Can you identify this lift. I think it's just a shackle lift as the body doughnuts seem to be stock. They are for the most part about 1-1 1/2 inches thick, what appears to be original, though in good condition and intact.
My concern is this:
With a simple shackle 'lift' I believe it has effectively lost some Caster for the steering. The symptoms are touchy steering at road speed. I live out in the Rural part of southern North Carolina and while our roads tend to be narrow and not exactly flat high speed through fares, their better than some places I'v lived, like So Cal and Anchorage Alaska. The purpose of the question involves caster shims for the front axle to return the steering more towards self centering. I don't believe my 95 YJ 4.0 has seen much dirt, at least on a regular basis, maybe dirt roads or double tracks in the woods, but still the steering could be better. The toe in seems pretty close is what I'm getting to.
As you can see, I have these American Racing Pythons with 31's on them, with some + offset ...unknown at what inches they are outwardy.
And lastly, if I add shims to the axle, say 2 degree or 4 degree, would I be able to loosen the 'U' bolts and plate and insert the shims and sinch it all back up without monkieing up something else? Anything to pay close attention to? I mean, this seems simple to me, and I'd consider myself an 8 out of 10 as a motorhead. Simple fix?
The rear dogleg shackle is measured from top edge to bottom edge...
Gohot is offline
post #2 of 18 Old 08-02-2012, 05:09 AM
Louie4
My concern is this:
As you can see, I have these American Racing Pythons with 31's on them, with some + offset ...unknown...what inches they are outward.
You could put some shackles on (4" bolt centers) and it should help with any wandering. You may want to consider having a shop do an alignment just to see though. As far as shims, I don't think you would need them for your setup if everything is properly torqued and the front wheels had the proper toe in. Something else to consider is the unit hub hearings, ball joints, and tie rod ends. Are they in good shape?
Lastly, are there any part numbers on the springs to help us identify the lift?
Also, ditch the track bar in the front and rear. Your jeep will ride much better.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 18 Old 08-02-2012, 05:16 AM
ZeroGravity
The sprigs are not stock, you can see how One of leafs in the pack wraps around the eye. it's called a military wrap, if you happen to snap a main leaf there's still something to support your vehicle, although the support from the frame end and the other spring is generally enough to keep it from dropping to the ground. As for identity, not many companies offer military wrap, so you can defiantly narrow it down. Also, the trAnsfer case drop uses pucks which are also mfg specific.
The shackles are measured eye to eye, if that's the case it looks like you have shackles an in inch longer than stock which gives you ~1/2" lift.
I'd say you're probably around 4-5" over stock. First jeep??
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #4 of 18 Old 08-02-2012, 06:16 AM
Nafpu
2012 KK Liberty
Why put booms in the rear, but not the front as well?
95 YJ, gone...
80 CJ7, gone...
12 KK, still here...
Nafpu is offline
post #5 of 18 Old 08-02-2012, 06:33 AM
gunshw301
Booms not needed in the front. You will have to stick with extended shackles with double wrap springs. You won't have any room for movement other wise. Might be able to drop the shackle length to somewhere around 5 to 6 inches center to center eye. Which they might already be siZed at.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #6 of 18 Old 08-02-2012, 06:59 AM Thread Starter
Gohot
Yep, first jeep, ans a trade from a previous owner who didn't know any specifics beyond it had a 'cool' sterio and sound bar'...lol. I'v come to expect a lack of knowledge as to the components, especially as it changed hands from the installer to the next owner then to me leaving the 'next owner' ignorant of the componentry. It's what is to be expected. At this point, I'm just trying to figure out what it is that has been done. I'm content with the configuration as is, it suits me as I seldom would use the Jeep for gnarley roads or crawling. I'm more likely to go offroad to a creek or river and go panning for gold and set up a camp kind of thing. But the bottom line is that I know the steering self centering lacks just a scoush, and could be better at 'return to center'.
Gohot is offline
post #7 of 18 Old 08-02-2012, 09:23 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I would guess RE 2.5" spring with a 1" boom.
I didn't read the rest of the replies but is that what you were looking for? Are there any markings on the springs?
Luck Favours The Prepared
Anticanman is offline
post #8 of 18 Old 08-02-2012, 11:59 AM
roadyrob
1987 YJ Wrangler
^^^^^^^^^^^^ looks like rubicon express springs to me too. check the suspension out real good, steering parts, also toe in, shouldn't have a problem with your setup.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #9 of 18 Old 08-02-2012, 01:09 PM
MLJeeper
MLJeeper's Avatar
Agreed, looks like the RE standard duty springs.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #10 of 18 Old 08-02-2012, 01:49 PM
roadyrob
1987 YJ Wrangler
took another look at your pics, you also need to either install the extension bracket on the track bar or just take it off, its pulling your axle over alittle.
roadyrob is offline
post #11 of 18 Old 08-02-2012, 09:01 PM
rambo3489
Remove it! Track bars are for girls.
While your at it take the sway bar out too. WAAAYY more flex. And not horrible on road either. You will notice it in the first couple corners tho.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #12 of 18 Old 10-04-2012, 06:02 AM Thread Starter
Gohot
Track bar to go................as soon as it's not raining here. I got'a do everything outdoors, and this time of year its rainy or sprinkly all the time. I think Caster wedges are my answer. Yea the track bars are...... uh, I don't know what.... but seem to be a factory necesity for some reason unknown to most??? I don't like the way they shift the chassis when accelerating or decelerating. My problem on the rear will be cutting the weld where the PO welded/tacked the through bolt to the axle mount. I can get the nut off, but the bolt is welded. '''Some peoples kids''' ???
Gohot is offline
post #13 of 18 Old 02-11-2013, 07:34 AM Thread Starter
Gohot
Ok a couple months have passed. The usual 145K mileage point necessities, ie. a new clutch kit and master and slave clutch kit. The clutch is all new now as well as hydraulic system.
Now back to the problem.... It does wander, or rather it doesn't self center much at all. As roadyrob pointed out in his assessment of the spring type, I'm not certain, but the Letter prefix would lead me to believe they were 'Rubicon Express Springs' Here's a shot of the stencil/letters on the rear of the drivers side. Both front springs have these numbers, honestly the rears I didn't check other than to note they have Wedges installed as well as a transfer case drop of 1.5" it appears, made with what almost look like Hockey pucks. They are about 2.5" and round, of some very hard non-metallic material. I'v sent off to Harbor Freight for a caster degree measuring gauge just a few minutes ago, so I know I'll need to measure caster before the determination of which degree wedges I will need.
Yea this is my first Jeep, and I'm finding it suits me well and my lifestyle of a retired old duff living on a farm in the country.
Gohot is offline
post #14 of 18 Old 02-11-2013, 07:57 AM
ionakana
Grand Poobah
ionakana's Avatar
The RE stands for Rubicon Express, those are 2.5" lift springs.
Psalm 14:1
Live in Georgia? click here-->
ionakana is offline
post #15 of 18 Old 02-11-2013, 08:41 AM
bgredjeep
1987 YJ Wrangler
So did you remove or relocate the track bar?
bgredjeep is offline
Can anyone identify this lift? Lerawk JK Wrangler Technical Forum 9 06-17-2011 06:29 PM
Help me identify the lift(s) on my TJ Danacus TJ Wrangler Technical Forum 5 04-11-2011 04:40 PM
please help me identify this lift... 02jeepwrangler TJ Wrangler Technical Forum 11 06-14-2010 06:30 PM
Identify lift tims03TJ TJ Wrangler Technical Forum 12 12-24-2009 02:58 PM
Identify This Lift .. SuMeRiaN TJ Wrangler Technical Forum 13 06-28-2007 09:17 PM
