Identification for 4 or 6 - JeepForum.com
post #1 of 6 Old 02-25-2009, 12:27 PM Thread Starter
brichardson7
I'm in the market for another YJ since having my son. (Finally, another Jeep). While scanning local ads and of course craigslist for YJ's for sale, I use pictures I see for some basis as to whether or not I go and look at the YJ closer.
With that said, is there any way to tell if a YJ's a 4 or 6 cyl with out popping the hood? I have found a few I liked but doesn't give a motor size. With my 89 I had it had the side steps that blended into the fender flairs(Sahara). Are the side steps an indicator? Please help. I miss my Jeep.
brichardson7 is offline
post #2 of 6 Old 02-25-2009, 12:43 PM
ElvisV04290
ElvisV04290's Avatar
Most 4.0s have a sticker on the back right under the tail light that says 4.0. I guess that's one way to tell.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member
Weber 32/36 Install ->
Early YJ Club Member #37
For anyone with a 4.2L -->
ElvisV04290 is offline
post #3 of 6 Old 02-25-2009, 12:49 PM
Jkanly
for a 4cyl the oil pan would be farther back in the engine bay, and there is about an extra foot of room between the rad and the accessory brackets. Other than that, front driveshaft is quite a bit smaller and shorter than the 6.
You can also check the vin... ?
l _____
/l
,[____],
l---L 0lllllll0-
()_)-()_)--o-)_)
Jkanly is offline
post #4 of 6 Old 02-25-2009, 12:56 PM
kloppk
kloppk is offline
post #5 of 6 Old 02-25-2009, 04:28 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
If it isn't brand new I would make no assumptions about what is actually under the hood given the extent that mods can be done to them!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #6 of 6 Old 02-25-2009, 05:16 PM
jeepdude1987
1987 YJ Wrangler
There isn't really a way to tell which engine there is unless it says 4.0 on the body, and that is no garuntee.
1987 Wrangler YJ RED 4.2 5-speed, NP231, BFG 31x10.5R15 AT/KO on 15x8 gambler wheels.
Caution!!! Under construction!!!!!! Caution!!!
Finishing a 4.0 Cyl.head swap, Just got an AX-15 NP231J combo to replace the busted t-case and craptacular BA10/5. Adding Nutter bypass. Probably more to come before it is back as a DD!
jeepdude1987 is offline
D44 Identification numbers jshoup02 TJ Wrangler Technical Forum 7 08-24-2009 01:43 PM
Identification, What is this???? Why J? YJ Wrangler Technical Forum 22 04-27-2009 09:41 PM
PCM identification BlueDevil YJ Wrangler Technical Forum 1 06-19-2006 12:24 PM
Identification help (w/pic) 95YJRookie YJ Wrangler Technical Forum 6 05-19-2006 02:43 PM
need help with identification stillen YJ Wrangler Technical Forum 4 12-04-2005 05:34 AM
