Ideas on gas tank re-shape? - JeepForum.com
post #1 of 4 Old 02-23-2013, 09:02 AM Thread Starter
rambo3489
Hey guys,
Here's the story. Going to start building my rig. I am going to run waggy springs on the front and rear to net me a little stretch. I am looking for 2 maybe 3" per axle whichever the offset pin and a 1" offset perch will get me. My problem as you know is in the rear with the tank. In the planning stage I looked into a genright tank to allow the clearance I seek. But those bad boys run $900 these days. I could have swung $700 like I believe they used to be. But said no way to $900.
I will be running a 9" SUA in the rear. I thought about the self clearance technique but dont think that would work to well if I end up with 3" of stretch and the larger 9" diff. I am looking for ideas on how I could re-shape or mold the gas tank to allow for proper clearance. I am not worried about the tank skid. I have the resources to modify that to whatever the tank comes out to be.
From the info I gathered I heat the tank. But am unsure with what. Would a propane torch be enough or should I look into an actual acetylene torch? Then I was thinking about heating some type of metal form to press into the tank to make a notch or a channel type thing. I have seen people recommend heating and beating it with a sledge. Is the tank really that hard to mold even with heat? Anyways looking for ideas / suggestions on how to mold the poly tank?
Thanks
Tyler
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #2 of 4 Old 02-23-2013, 09:06 AM
scubamc
Everything you need to know is right here.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #3 of 4 Old 02-23-2013, 09:11 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I also got some good advice here:
http://www.jeepforum.com/forum/f12/r...09/?highlight=
Luck Favours The Prepared
Anticanman is offline
post #4 of 4 Old 02-23-2013, 09:15 AM
skyj
Check out these three build threads all of us have done it. like I mentioned in Canmans thread above there was mention of a camero tank that already has a dimple its mentioned in the pirate thread ,but no one seemed to elaberate on it. http://www.jeepforum.com/forum/f12/s...build-1467426/
http://www.jeepforum.com/forum/f12/j...rsion-1341575/
http://www.jeepforum.com/forum/f12/s...hread-1237931/
build thread:
skyj is offline
